Razer DeathAdder Chroma USB Cable Replacement
  1. Razer DeathAdder Chroma USB Cable Replacement, Outer Casing: step 1, image 1 of 1
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Turn the mouse over so the bottom is facing up.
  2. Razer DeathAdder Chroma USB Cable Replacement: step 2, image 1 of 2 Razer DeathAdder Chroma USB Cable Replacement: step 2, image 2 of 2
    • Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
  3. Razer DeathAdder Chroma USB Cable Replacement: step 3, image 1 of 2 Razer DeathAdder Chroma USB Cable Replacement: step 3, image 2 of 2
    • Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
  4. Razer DeathAdder Chroma USB Cable Replacement: step 4, image 1 of 1
    • Use your fingers to identify the location of the screw under the bottom label.
  5. Razer DeathAdder Chroma USB Cable Replacement: step 5, image 1 of 1
    • Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
    • Clear the label away from around the screw for easier removal.
  6. Razer DeathAdder Chroma USB Cable Replacement: step 6, image 1 of 3 Razer DeathAdder Chroma USB Cable Replacement: step 6, image 2 of 3 Razer DeathAdder Chroma USB Cable Replacement: step 6, image 3 of 3
    • Turn the mouse over so the bottom is facing down.
    • Separate the top casing from the bottom base by pulling the top casing upwards.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
  7. Razer DeathAdder Chroma USB Cable Replacement: step 7, image 1 of 2 Razer DeathAdder Chroma USB Cable Replacement: step 7, image 2 of 2
    • Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
    • Pulling too hard could damage the wire connections.
  8. Razer DeathAdder Chroma USB Cable Replacement, Motherboard: step 8, image 1 of 2 Razer DeathAdder Chroma USB Cable Replacement, Motherboard: step 8, image 2 of 2
    • Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
  9. Razer DeathAdder Chroma USB Cable Replacement: step 9, image 1 of 1
    • Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
  10. Razer DeathAdder Chroma USB Cable Replacement: step 10, image 1 of 2 Razer DeathAdder Chroma USB Cable Replacement: step 10, image 2 of 2
    • Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
  11. Razer DeathAdder Chroma USB Cable Replacement: step 11, image 1 of 1
    • Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
  12. Razer DeathAdder Chroma USB Cable Replacement: step 12, image 1 of 2 Razer DeathAdder Chroma USB Cable Replacement: step 12, image 2 of 2
    • Disconnect the ribbon connector between the motherboard and the optical sensor.
  13. Razer DeathAdder Chroma USB Cable Replacement: step 13, image 1 of 2 Razer DeathAdder Chroma USB Cable Replacement: step 13, image 2 of 2
    • Remove the motherboard by grasping the sides and gently pulling upward.
  14. Razer DeathAdder Chroma USB Cable Replacement, USB Cable: step 14, image 1 of 1
    • Locate the USB cable.
  15. Razer DeathAdder Chroma USB Cable Replacement: step 15, image 1 of 2 Razer DeathAdder Chroma USB Cable Replacement: step 15, image 2 of 2
    • Remove the USB cable by pulling it up and out.
7 other people completed this guide.
Henry Shi
221 Reputation
1 Guide authored
Baylor, Team S5-G2, Williams Spring 2017 Member of Baylor, Team S5-G2, Williams Spring 2017
BU-WILLIAMS-S17S5G2
3 Members
6 Guides authored
5 Comments
Thank you! It realy worked. Btw: The cable for the Deathadder 2013 is working for the Chroma and Elite as well. I Just tried it :)
Pokefreeks - Reply
Thanks for the advice
João Costa Santos -
Great and easy guide thanx alot, saved me a new mouse :)
jesperkb - Reply
Is there a reliable website where I can get a replacement cable with low delivery time?
Bubbles EXE - Reply
where can i get the cable from?
Mourya Singham - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 27
All Time: 14,702
