Razer Huntsman TE Keycaps Replacement
  1. Razer Huntsman TE Keycaps Replacement, Keycaps: step 1, image 1 of 2 Razer Huntsman TE Keycaps Replacement, Keycaps: step 1, image 2 of 2
    • Identify the correct type of key to replace.
    • Keys such as "Shift" and "Enter" have multiple slots, and each slot has a different shape, so be sure to pick the correct one.
  2. Razer Huntsman TE Keycaps Replacement: step 2, image 1 of 2 Razer Huntsman TE Keycaps Replacement: step 2, image 2 of 2
    • Insert the keycap puller so that the teeth at the end of the puller sit beneath the keycap.
    • Apply enough upwards force for the keycap to pop out.
  3. Razer Huntsman TE Keycaps Replacement: step 3, image 1 of 2 Razer Huntsman TE Keycaps Replacement: step 3, image 2 of 2
    Tool used on this step:
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • Apply 91% isopropyl alcohol to microfiber cloth.
    • Wipe around the key.
    • Make sure that there is no residual stickiness on the key.
  4. Razer Huntsman TE Keycaps Replacement: step 4, image 1 of 2 Razer Huntsman TE Keycaps Replacement: step 4, image 2 of 2
    • Position the replacement keycap above the keyslot.
    • Using your finger, apply downwards force to the keycap until you hear it snap into place.
Use a diagnostic tool such as an online keyboard tester to test the key.
Lucas de Castro
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 43
All Time: 2,595
