Razer Huntsman Tournament Edition Key Switch Replacement
  1. Razer Huntsman Tournament Edition Key Switch Replacement, Keycaps: step 1, image 1 of 1
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
  2. Razer Huntsman Tournament Edition Key Switch Replacement: step 2, image 1 of 2 Razer Huntsman Tournament Edition Key Switch Replacement: step 2, image 2 of 2
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
  3. Razer Huntsman Tournament Edition Key Switch Replacement: step 3, image 1 of 3 Razer Huntsman Tournament Edition Key Switch Replacement: step 3, image 2 of 3 Razer Huntsman Tournament Edition Key Switch Replacement: step 3, image 3 of 3
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
  4. Razer Huntsman Tournament Edition Key Switch Replacement, Chassis: step 4, image 1 of 1
    • Remove all of the keycaps with a keycap puller.
  5. Razer Huntsman Tournament Edition Key Switch Replacement: step 5, image 1 of 2 Razer Huntsman Tournament Edition Key Switch Replacement: step 5, image 2 of 2
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
  6. Razer Huntsman Tournament Edition Key Switch Replacement: step 6, image 1 of 1
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
  7. Razer Huntsman Tournament Edition Key Switch Replacement: step 7, image 1 of 1
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
  8. Razer Huntsman Tournament Edition Key Switch Replacement: step 8, image 1 of 1
    • Disconnect the internal cable.
  9. Razer Huntsman Tournament Edition Key Switch Replacement, Key Switch: step 9, image 1 of 2 Razer Huntsman Tournament Edition Key Switch Replacement, Key Switch: step 9, image 2 of 2
    • Gently push the key switch off of the mainboard with your thumb.
Joseph O'Dowd
383 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 60
All Time: 1,286
