Razer Huntsman Tournament Edition Port Replacement
  1. Razer Huntsman Tournament Edition Port Replacement, Keycaps: step 1, image 1 of 1
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
  2. Razer Huntsman Tournament Edition Port Replacement: step 2, image 1 of 2 Razer Huntsman Tournament Edition Port Replacement: step 2, image 2 of 2
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
  3. Razer Huntsman Tournament Edition Port Replacement: step 3, image 1 of 3 Razer Huntsman Tournament Edition Port Replacement: step 3, image 2 of 3 Razer Huntsman Tournament Edition Port Replacement: step 3, image 3 of 3
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
  4. Razer Huntsman Tournament Edition Port Replacement, Chassis: step 4, image 1 of 1
    • Remove all of the keycaps with a keycap puller.
  5. Razer Huntsman Tournament Edition Port Replacement: step 5, image 1 of 2 Razer Huntsman Tournament Edition Port Replacement: step 5, image 2 of 2
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
  6. Razer Huntsman Tournament Edition Port Replacement: step 6, image 1 of 1
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
  7. Razer Huntsman Tournament Edition Port Replacement: step 7, image 1 of 1
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
  8. Razer Huntsman Tournament Edition Port Replacement: step 8, image 1 of 1
    • Disconnect the internal cable.
  9. Razer Huntsman Tournament Edition Port Replacement, Port: step 9, image 1 of 2 Razer Huntsman Tournament Edition Port Replacement, Port: step 9, image 2 of 2
    • Unscrew the board with the port.
    • It should be located on the upper left, held in by two 6.5mm Phillips #0 screws.
    • Move the cable out of the way for the second screw
  10. Razer Huntsman Tournament Edition Port Replacement: step 10, image 1 of 1
    • Detach the internal cable from the USB board.
    • Do this carefully.
  11. Razer Huntsman Tournament Edition Port Replacement: step 11, image 1 of 1
    • Remove the USB board.
Joseph O'Dowd
383 Reputation
3 Guides authored
One Comment
how do i get a new port and where
Guardian Suit - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 331
