Razer Kraken Ultimate Speaker Replacement
  1. Razer Kraken Ultimate Speaker Replacement, Ear Pads: step 1, image 1 of 3 Razer Kraken Ultimate Speaker Replacement, Ear Pads: step 1, image 2 of 3 Razer Kraken Ultimate Speaker Replacement, Ear Pads: step 1, image 3 of 3
    • Grab the ear piece from one of the sides and lightly pull it outwards.
    • Ideally, do not pull the ear piece directly away from the speaker; it may damage the piece.
  2. Razer Kraken Ultimate Speaker Replacement: step 2, image 1 of 2 Razer Kraken Ultimate Speaker Replacement: step 2, image 2 of 2
    • Once you have taken off one side, you can then remove the whole piece by slowly prying the pad away from the headphones.
  3. Razer Kraken Ultimate Speaker Replacement: step 3, image 1 of 2 Razer Kraken Ultimate Speaker Replacement: step 3, image 2 of 2
    • Repeat steps on the other side.
  4. Razer Kraken Ultimate Speaker Replacement, Speaker: step 4, image 1 of 3 Razer Kraken Ultimate Speaker Replacement, Speaker: step 4, image 2 of 3 Razer Kraken Ultimate Speaker Replacement, Speaker: step 4, image 3 of 3
    • Remove the four 10 mm Phillips #00 screws securing the right speaker.
    • Be sure the device is unplugged before attempting to remove any of the screws.
  5. Razer Kraken Ultimate Speaker Replacement: step 5, image 1 of 2 Razer Kraken Ultimate Speaker Replacement: step 5, image 2 of 2
    • Remove the 10 mm Phillips #00 screws securing the left speaker.
    • Note that one of the screws is hidden behind the product information sticker. Use your screw driver to punch a hole in the sticker.
  6. Razer Kraken Ultimate Speaker Replacement: step 6, image 1 of 2 Razer Kraken Ultimate Speaker Replacement: step 6, image 2 of 2
    • To fully detach the speakers cut the wires as close as possible to the connection point, leaving plenty of room to solder the new speaker on.
Alex Broggi
342 Reputation
3 Guides authored
UMass Dartmouth, Team 1-4, Petersen Fall 2022 Member of UMass Dartmouth, Team 1-4, Petersen Fall 2022
UMASSD-PETERSEN-F22S1G4
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 29
All Time: 496
