Razer Ouroboros Lock Switch Replacement
  1. Razer Ouroboros Lock Switch Replacement, Left and Right Trigger Switch: step 1, image 1 of 2 Razer Ouroboros Lock Switch Replacement, Left and Right Trigger Switch: step 1, image 2 of 2
    • Flip the mouse over and remove the stickers on the back of the device. These stickers are hiding the screws we need to remove.
    • Locate and remove the captive screws to remove the hand rest.
  2. Razer Ouroboros Lock Switch Replacement: step 2, image 1 of 2 Razer Ouroboros Lock Switch Replacement: step 2, image 2 of 2
    • Locate and remove the six 4mm screws on the back of the device.
    • Slide the side panels off the back of the mouse.
  3. Razer Ouroboros Lock Switch Replacement: step 3, image 1 of 2 Razer Ouroboros Lock Switch Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Using your tweezers, grab the trigger switch that you want to replace, and lift it from its slot.
    • If you have your replacement switch, place it in the newly freed slot and reassemble your device.
    • Note: the top guards of this mouse can come off now that the panel screws have been removed. Make sure these stay in place when reassembling.
Preston Darling
372 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 3,564
