Razor AW Kick Wheel Bar Replacement
  1. Razor AW Kick Wheel Bar Replacement, Wheel Bar: step 1, image 1 of 3 Razor AW Kick Wheel Bar Replacement, Wheel Bar: step 1, image 2 of 3 Razor AW Kick Wheel Bar Replacement, Wheel Bar: step 1, image 3 of 3
    • Place the scooter on its side and on the ground.
    • Place the 5 mm Hex Security key into the screw, and secure the other side of the screw with another 5 mm Hex Security key to keep it from spinning around.
    • Remove the screw using the 5 mm Hex Security key.
    • Remove the screw from the scooter frame.
  2. Razor AW Kick Wheel Bar Replacement: step 2, image 1 of 3 Razor AW Kick Wheel Bar Replacement: step 2, image 2 of 3 Razor AW Kick Wheel Bar Replacement: step 2, image 3 of 3
    • Remove the wheel from the scooter slowly.
    • Remove the black wheel holders from the scooter frame.
  3. Razor AW Kick Wheel Bar Replacement: step 3, image 1 of 2 Razor AW Kick Wheel Bar Replacement: step 3, image 2 of 2
    • Remove the wheel bar from the scooter frame.
To reassemble your device, follow these instructions in revise order.
Alexander Vazquez
97 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 207
