Razor Hovertrax 2.0 Anti-Slip Pads Replacement
  1. Razor Hovertrax 2.0 Anti-Slip Pads Replacement, Anti-Slip Pads: step 1, image 1 of 1
    • Choose an area to access and slip the Jimmy blade to pry open the pad.
    • We recommend prying the pad open from the top and bottom instead of the sides due to the plastic wheel cover blocking the access point.
  2. Razor Hovertrax 2.0 Anti-Slip Pads Replacement: step 2, image 1 of 1
    • After using the Jimmy tool to open up the area, use your hands and slowly peel off the adhesive from the pad and board.
    • You may be required to remove the remaining adhesive on the board.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 33
