Razor Hovertrax 2.0 Charging Port Replacement
  1. Razor Hovertrax 2.0 Charging Port Replacement, Battery: step 1, image 1 of 2 Razor Hovertrax 2.0 Charging Port Replacement, Battery: step 1, image 2 of 2
    • Use a #2 Philips screwdriver to remove the eight 18.5 mm screws from the bottom of the Hovertrax 2.0.
  2. Razor Hovertrax 2.0 Charging Port Replacement: step 2, image 1 of 2 Razor Hovertrax 2.0 Charging Port Replacement: step 2, image 2 of 2
    • To remove the led connector from the board, press the clip in with your fingers and gently pull up.
    • The connector you are removing is black and has two pins.
    • If it does not want to come out, gently wiggle the connector side to side while pulling up.
  3. Razor Hovertrax 2.0 Charging Port Replacement: step 3, image 1 of 1
    • Disconnect the battery connector by grabbing the black side with one hand and the yellow side with the other hand and gently pull apart. (Try not to pull on the wires, it could damage them)
    • If you are replacing other parts, leave the battery disconnected until the end.
  4. Razor Hovertrax 2.0 Charging Port Replacement: step 4, image 1 of 2 Razor Hovertrax 2.0 Charging Port Replacement: step 4, image 2 of 2
    • Remove the two 17.2 mm hex head bolts using the 4 mm hex screwdriver that secures the battery in place.
  5. Razor Hovertrax 2.0 Charging Port Replacement: step 5, image 1 of 1
    • The battery should be able to be lifted up out of the device now.
  6. Razor Hovertrax 2.0 Charging Port Replacement, Charging Port: step 6, image 1 of 2 Razor Hovertrax 2.0 Charging Port Replacement, Charging Port: step 6, image 2 of 2
    • Use a #2 Phillips Screwdriver to remove the circled screws.
  7. Razor Hovertrax 2.0 Charging Port Replacement: step 7, image 1 of 3 Razor Hovertrax 2.0 Charging Port Replacement: step 7, image 2 of 3 Razor Hovertrax 2.0 Charging Port Replacement: step 7, image 3 of 3
    • Remove the black shell with the warning stickers.
    • Be cautious of the two wires attached to the circuit board when lifting the shell
    • Carefully disconnect the two connectors from the circuit board.
    • The two connectors you are disconnecting are black and have two pins.
  8. Razor Hovertrax 2.0 Charging Port Replacement: step 8, image 1 of 3 Razor Hovertrax 2.0 Charging Port Replacement: step 8, image 2 of 3 Razor Hovertrax 2.0 Charging Port Replacement: step 8, image 3 of 3
    • Remove the hot glue covering the charging port
    • Our team was able to remove the hot glue by peeling is off with our fingers.
    • Use your fingertips to remove the nut.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 64
