Rear Turn Signal Bulb Replacement
  1. Rear Turn Signal Bulb Replacement, Rear Turn Signal Bulb: step 1, image 1 of 3 Rear Turn Signal Bulb Replacement, Rear Turn Signal Bulb: step 1, image 2 of 3 Rear Turn Signal Bulb Replacement, Rear Turn Signal Bulb: step 1, image 3 of 3
    • The stop/turn signal bulb is located in the outer rear lamp unit that is secured at the rear of each quarter panel
    • Open the tail gate and locate the two fasteners holding the light assembly to the quarter panel.
    • Locate the notches in the outer ring of the fasteners. Those are to facilitate the use of a screw driver to remove the fasteners.
  2. Rear Turn Signal Bulb Replacement: step 2, image 1 of 3 Rear Turn Signal Bulb Replacement: step 2, image 2 of 3 Rear Turn Signal Bulb Replacement: step 2, image 3 of 3
    • Insert a flathead screwdriver or similar tool and pry out the center of the fastener
    • A pair of pliers, or similar tool, can be used to get a better hold on the fastener
    • Completely remove the fastener
  3. Rear Turn Signal Bulb Replacement: step 3, image 1 of 3 Rear Turn Signal Bulb Replacement: step 3, image 2 of 3 Rear Turn Signal Bulb Replacement: step 3, image 3 of 3
    • Proceed the same way with the bottom fastener. Pry out the center.
    • Use pliers or similar tool to pull the fastener
    • Completely remove fastener
  4. Rear Turn Signal Bulb Replacement: step 4, image 1 of 3 Rear Turn Signal Bulb Replacement: step 4, image 2 of 3 Rear Turn Signal Bulb Replacement: step 4, image 3 of 3
    • The tail light assembly is still held in place by two guide pegs. Gently pull the complete assembly toward the rear of the vehicle to unseat the pegs.
    • Fully remove the tail light assembly
    • The assembly can rest on the top of the rear bumper. The Stop/Turn signal bulb is the larger one of the two bulb fixtures.
  5. Rear Turn Signal Bulb Replacement: step 5, image 1 of 3 Rear Turn Signal Bulb Replacement: step 5, image 2 of 3 Rear Turn Signal Bulb Replacement: step 5, image 3 of 3
    • Remove the bulb socket by turning it about 1/4 turn in a counter clockwise direction
    • Remove the socket from the light assembly
    • Remove the bulb from the socket by pulling it straight out.
  6. Rear Turn Signal Bulb Replacement: step 6, image 1 of 1
    • Replace the burned out bulb with a new type 3057 dual filament bulb
3 other people completed this guide.
oldturkey03
837,525 Reputation
123 Guides authored
5 Guide Comments
What if the trunk don’t open is it possible to change a blinker bulb ?
Shellie Gill - Reply
No. Step 1 picture 2 can't be accessed if it does not open
oldturkey03 -
I'm a female and I will give it a try.
janice_montalto - Reply
1*Onde posso ter informações de como trocar a lampada do farol dianteiro ?
2* Meu carro entrou água e agora as setas fficam piscando, algo q posso resolver ?
Tharles - Reply
3* comprei um .módulo de tração que fica embaixo do banco do motorista , mais ao colocar o carro não reconheceu, com9 resolver?
Tharles - Reply
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 60
All Time: 20,461
