Recharging A/C Refrigerant for 2016 Hyundai Elantra
  1. Recharging A/C Refrigerant for 2016 Hyundai Elantra, Recharging A/C Refrigerant for 2016 Hyundai Elantra: step 1, image 1 of 1
    • Get refrigerant and read the pressure chart carefully. This is located on the side of the can.
  2. Recharging A/C Refrigerant for 2016 Hyundai Elantra: step 2, image 1 of 3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: step 2, image 2 of 3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: step 2, image 3 of 3
    • Find and pull the lever to the hood on the driver's side of the vehicle.
  3. Recharging A/C Refrigerant for 2016 Hyundai Elantra: step 3, image 1 of 3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: step 3, image 2 of 3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: step 3, image 3 of 3
    • Lift the hood while pulling the lever under the center of the hood. Next, prop up the hood with the hood strut.
  4. Recharging A/C Refrigerant for 2016 Hyundai Elantra: step 4, image 1 of 2 Recharging A/C Refrigerant for 2016 Hyundai Elantra: step 4, image 2 of 2
    • Locate the low-pressure port by following the low-pressure hose (the cap will have an "L" on it).
  5. Recharging A/C Refrigerant for 2016 Hyundai Elantra: step 5, image 1 of 2 Recharging A/C Refrigerant for 2016 Hyundai Elantra: step 5, image 2 of 2
    • Shake the can well.
  6. Recharging A/C Refrigerant for 2016 Hyundai Elantra: step 6, image 1 of 1
    • Connect the refrigerant hose to the low-pressure port.
  7. Recharging A/C Refrigerant for 2016 Hyundai Elantra: step 7, image 1 of 1
    • Start the vehicle and turn on the A/C all the way on.
  8. Recharging A/C Refrigerant for 2016 Hyundai Elantra: step 8, image 1 of 3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: step 8, image 2 of 3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: step 8, image 3 of 3
    • While tipping the can 90 degrees back and forth, fill your vehicle (until the gauge reads as the can specifies).
To recharge your vehicle, follow these instructions in order.
0 Comments
Past 24 Hours: 23
Past 7 Days: 180
Past 30 Days: 817
All Time: 9,090
