RedOctane X-Plorer Keys Replacement
  1. RedOctane X-Plorer Keys Replacement, Rear Case: step 1, image 1 of 2 RedOctane X-Plorer Keys Replacement, Rear Case: step 1, image 2 of 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Keys Replacement: step 2, image 1 of 3 RedOctane X-Plorer Keys Replacement: step 2, image 2 of 3 RedOctane X-Plorer Keys Replacement: step 2, image 3 of 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Keys Replacement: step 3, image 1 of 3 RedOctane X-Plorer Keys Replacement: step 3, image 2 of 3 RedOctane X-Plorer Keys Replacement: step 3, image 3 of 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Keys Replacement, Keys: step 4, image 1 of 3 RedOctane X-Plorer Keys Replacement, Keys: step 4, image 2 of 3 RedOctane X-Plorer Keys Replacement, Keys: step 4, image 3 of 3
    • Use a screwdriver to remove the 10 mm Phillips #1 screws from the key sensor board.
    • Lift up on the key sensor board to remove it from the guitar neck.
    • When using the screwdriver, make sure to avoid puncturing the wires.
  5. RedOctane X-Plorer Keys Replacement: step 5, image 1 of 1
    • Using your fingers, remove the rubber pad to expose the colored keys.
  6. RedOctane X-Plorer Keys Replacement: step 6, image 1 of 2 RedOctane X-Plorer Keys Replacement: step 6, image 2 of 2
    • Reach one finger under the guitar to push the key out of the casing.
    • Repeat this step for the four remaining keys.
3 other people completed this guide.
Ashley Slocum
228 Reputation
1 Guide authored
Cal Poly, Team S17-G1, Livingston Spring 2018 Member of Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 40
All Time: 4,644
