RedOctane X-Plorer Rubber Button Strip Replacement
  1. RedOctane X-Plorer Rubber Button Strip Replacement, Rubber Button Strip: step 1, image 1 of 2 RedOctane X-Plorer Rubber Button Strip Replacement, Rubber Button Strip: step 1, image 2 of 2
    • Remove the controller's strap, which will be attached at the points in the red circles.
    • If your controller does not have a strap, move to the next step.
  2. RedOctane X-Plorer Rubber Button Strip Replacement: step 2, image 1 of 1
    • Remove all nine 12mm screws around the perimeter of the body of the controller, using the Phillips #2 screwdriver.
    • Remove the two 15mm screws near the neck of the controller, using the Phillips #2 screwdriver.
  3. RedOctane X-Plorer Rubber Button Strip Replacement: step 3, image 1 of 2 RedOctane X-Plorer Rubber Button Strip Replacement: step 3, image 2 of 2
    • Using your hands, remove the body shell.
  4. RedOctane X-Plorer Rubber Button Strip Replacement: step 4, image 1 of 1
    • Remove all seven 12mm screws on the neck of the controller using the Phillips #2 screwdriver.
  5. RedOctane X-Plorer Rubber Button Strip Replacement: step 5, image 1 of 2 RedOctane X-Plorer Rubber Button Strip Replacement: step 5, image 2 of 2
    • Using your hands, remove the top shell of neck.
  6. RedOctane X-Plorer Rubber Button Strip Replacement: step 6, image 1 of 1
    Tool used on this step:
    Flathead 1.5 mm Screwdriver
    $5.49
    Buy
    • Remove the left 1.5mm mm screw (as shown) on the key sensor board, using the 1.5mm flathead screwdriver.
    • Do not remove the other (right-side) screw on key sensor board, as this can cause damage to the circuitry.
  7. RedOctane X-Plorer Rubber Button Strip Replacement: step 7, image 1 of 2 RedOctane X-Plorer Rubber Button Strip Replacement: step 7, image 2 of 2
    • Using your hands, remove the rubber button strip.
  8. RedOctane X-Plorer Rubber Button Strip Replacement: step 8, image 1 of 2 RedOctane X-Plorer Rubber Button Strip Replacement: step 8, image 2 of 2
    • Using your hands, insert the replacement strip underneath the key sensor board.
  9. RedOctane X-Plorer Rubber Button Strip Replacement: step 9, image 1 of 2 RedOctane X-Plorer Rubber Button Strip Replacement: step 9, image 2 of 2
    • Align the black dots on the rubber strip with the corresponding button indicator before rescrewing key sensor board.
    • The first button will be "A" on Xbox and Wii, and "X" on Playstation.
Stephen Haning
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 13
All Time: 390
