Redragon K552 Key Switch Replacement
  1. Redragon K552 Key Switch Replacement, Key Switch: step 1, image 1 of 3 Redragon K552 Key Switch Replacement, Key Switch: step 1, image 2 of 3 Redragon K552 Key Switch Replacement, Key Switch: step 1, image 3 of 3
    • Unplug the keyboard from the computer.
    • Because this keyboard does not use a detachable cable, you will have to detach the cable from the PC directly.
    • The location of the cable depends on how you had installed the keyboard into the PC. (In my case, I have it installed on the rear of my PC next to my ethernet cable).
    • RGB lights indicate that power is running through the keyboard.
    • Make sure that no power is running through the keyboard during the replacement process.
  2. Redragon K552 Key Switch Replacement: step 2, image 1 of 3 Redragon K552 Key Switch Replacement: step 2, image 2 of 3 Redragon K552 Key Switch Replacement: step 2, image 3 of 3
    • Align the keycap puller to the keycap.
    • Use the keycap puller to pull out all the keycaps from the keyboard.
  3. Redragon K552 Key Switch Replacement: step 3, image 1 of 3 Redragon K552 Key Switch Replacement: step 3, image 2 of 3 Redragon K552 Key Switch Replacement: step 3, image 3 of 3
    • Dip cotton swabs into a bottle of rubbing alcohol solution.
    • Clean the keycaps using the cotton swabs.
  4. Redragon K552 Key Switch Replacement: step 4, image 1 of 3 Redragon K552 Key Switch Replacement: step 4, image 2 of 3 Redragon K552 Key Switch Replacement: step 4, image 3 of 3
    • Dip another cotton swab into the rubbing alcohol solution.
    • Carefully use the cotton swab to clean the surface and crevices of the keyboard.
    • Do not drop rubbing alcohol into the keyboard directly as it may cause damage to the keyboard.
  5. Redragon K552 Key Switch Replacement: step 5, image 1 of 3 Redragon K552 Key Switch Replacement: step 5, image 2 of 3 Redragon K552 Key Switch Replacement: step 5, image 3 of 3
    • Align the switch puller with the faulty key switch.
    • Pull the faulty key switch straight up from the keyboard.
  6. Redragon K552 Key Switch Replacement: step 6, image 1 of 3 Redragon K552 Key Switch Replacement: step 6, image 2 of 3 Redragon K552 Key Switch Replacement: step 6, image 3 of 3
    • Align the pins of the new switch to the keyboard.
    • Press the key switch on the keyboard until it clicks into place.
  7. Redragon K552 Key Switch Replacement: step 7, image 1 of 3 Redragon K552 Key Switch Replacement: step 7, image 2 of 3 Redragon K552 Key Switch Replacement: step 7, image 3 of 3
    • Replace all of the keycaps.
  8. Redragon K552 Key Switch Replacement: step 8, image 1 of 3 Redragon K552 Key Switch Replacement: step 8, image 2 of 3 Redragon K552 Key Switch Replacement: step 8, image 3 of 3
    • Plug the keyboard USB cable back to the PC.
    • Use a keyboard tester online to test your key switches.
Finish Line
Lyxander Blanco
187 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 70
All Time: 8,353
