Remington MB4040 Cover Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Remington MB4040 Cover Assembly Replacement, Remove Blade Assembly: step 1, image 1 of 3 Remington MB4040 Cover Assembly Replacement, Remove Blade Assembly: step 1, image 2 of 3 Remington MB4040 Cover Assembly Replacement, Remove Blade Assembly: step 1, image 3 of 3
    • Press the black button below the blade to remove the blade.
  2. Remington MB4040 Cover Assembly Replacement, Remove Back Cover Hardware: step 2, image 1 of 2 Remington MB4040 Cover Assembly Replacement, Remove Back Cover Hardware: step 2, image 2 of 2
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Remington MB4040 Cover Assembly Replacement, Remove Front Cover Hardware: step 3, image 1 of 3 Remington MB4040 Cover Assembly Replacement, Remove Front Cover Hardware: step 3, image 2 of 3 Remington MB4040 Cover Assembly Replacement, Remove Front Cover Hardware: step 3, image 3 of 3
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. Remington MB4040 Cover Assembly Replacement, Front Cover (cont.): step 4, image 1 of 2 Remington MB4040 Cover Assembly Replacement, Front Cover (cont.): step 4, image 2 of 2
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. Remington MB4040 Cover Assembly Replacement, Blade Button Removal: step 5, image 1 of 2 Remington MB4040 Cover Assembly Replacement, Blade Button Removal: step 5, image 2 of 2
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
Cameron Carnahan
1,112 Reputation
6 Guides authored
USF Tampa, Team 1-5, Blackwell Winter 2015 Member of USF Tampa, Team 1-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G5
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 176
