Remington MB4040 Thermal Switch Replacement
  1. Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: step 1, image 1 of 3 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: step 1, image 2 of 3 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: step 1, image 3 of 3
    • Press the black button below the blade to remove the blade.
  2. Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: step 2, image 1 of 2 Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: step 2, image 2 of 2
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: step 3, image 1 of 3 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: step 3, image 2 of 3 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: step 3, image 3 of 3
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): step 4, image 1 of 2 Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): step 4, image 2 of 2
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. Remington MB4040 Thermal Switch Replacement, Blade Button Removal: step 5, image 1 of 2 Remington MB4040 Thermal Switch Replacement, Blade Button Removal: step 5, image 2 of 2
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
  6. Remington MB4040 Thermal Switch Replacement, Remove Motherboard: step 6, image 1 of 2 Remington MB4040 Thermal Switch Replacement, Remove Motherboard: step 6, image 2 of 2
  7. Remington MB4040 Thermal Switch Replacement, Remove Thermal Switch: step 7, image 1 of 1
    • Separate the thermal switch from the battery by using a spudger to pry it from the adhesive.
    • Use a low temperature RTV to readhere the thermal switch to the battery.
    • Remove the soldering holding the thermal switch to the motherboard.
3 other people completed this guide.
Cameron Carnahan
1,082 Reputation
6 Guides authored
USF Tampa, Team 1-5, Blackwell Winter 2015 Member of USF Tampa, Team 1-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G5
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 24
All Time: 3,029
