Removal/Replacement of Dell Inspiron E1705 Hard Drive
  1. Removal/Replacement of Dell Inspiron E1705 Hard Drive, Battery: step 1, image 1 of 1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Removal/Replacement of Dell Inspiron E1705 Hard Drive: step 2, image 1 of 2 Removal/Replacement of Dell Inspiron E1705 Hard Drive: step 2, image 2 of 2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Removal/Replacement of Dell Inspiron E1705 Hard Drive, Hard Drive: step 3, image 1 of 2 Removal/Replacement of Dell Inspiron E1705 Hard Drive, Hard Drive: step 3, image 2 of 2
    • Remove the two Phillips #1 screws on the left side of the computer, just above the battery compartment.
    • These screws hold the hard drive tray into the hard drive compartment.
  4. Removal/Replacement of Dell Inspiron E1705 Hard Drive: step 4, image 1 of 1
    • Slide the hard drive tray out of the hard drive compartment.
3 other people completed this guide.
Malik Shahbal
471 Reputation
5 Guides authored
Cal Poly, Team 22-5, Maness Fall 2010 Member of Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 21
All Time: 20,437
