Remove Nintendo GameCube Optical Drive Assembly
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Remove Nintendo GameCube Optical Drive Assembly, Top Case: step 1, image 1 of 3 Remove Nintendo GameCube Optical Drive Assembly, Top Case: step 1, image 2 of 3 Remove Nintendo GameCube Optical Drive Assembly, Top Case: step 1, image 3 of 3
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Remove Nintendo GameCube Optical Drive Assembly: step 2, image 1 of 3 Remove Nintendo GameCube Optical Drive Assembly: step 2, image 2 of 3 Remove Nintendo GameCube Optical Drive Assembly: step 2, image 3 of 3
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
  3. Remove Nintendo GameCube Optical Drive Assembly, Remove Nintendo GameCube Optical Drive Assembly: step 3, image 1 of 2 Remove Nintendo GameCube Optical Drive Assembly, Remove Nintendo GameCube Optical Drive Assembly: step 3, image 2 of 2
    • The left side of the unit contains the cooling fan and its housing.
    • Carefully remove the two screws attaching the cooling fan housing to the unit.
    • Do not detach the red and black cooling fan wire from the main unit. Boxed in orange.
  4. Remove Nintendo GameCube Optical Drive Assembly: step 4, image 1 of 2 Remove Nintendo GameCube Optical Drive Assembly: step 4, image 2 of 2
    • Remove the four Phillips #1 screws retaining the ground springs.
    • Carefully remove the ground springs from the main unit.
  5. Remove Nintendo GameCube Optical Drive Assembly: step 5, image 1 of 2 Remove Nintendo GameCube Optical Drive Assembly: step 5, image 2 of 2
    • The optical drive is secured to a metal plate.
    • Using a Phillips #2 screwdriver, unscrew the twelve screws that are around the outer edge of the optical drive.
  6. Remove Nintendo GameCube Optical Drive Assembly, Remove the assembly: step 6, image 1 of 3 Remove Nintendo GameCube Optical Drive Assembly, Remove the assembly: step 6, image 2 of 3 Remove Nintendo GameCube Optical Drive Assembly, Remove the assembly: step 6, image 3 of 3
    • Carefully separate the optical drive assembly from the rest of the GameCube unit.
    • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
    • The metal plate and the actual optical drive will remain attached.
dcarlin
390 Reputation
4 Guides authored
Cal Poly, Team 6-2, Maness Fall 2009 Member of Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
4 Members
45 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 4,493
