Remove the chain guard
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Careful: steps 1-4 are sourced from a guide that's marked as in-progress.
    Remove the chain guard, Safety precautions: step 1, image 1 of 2 Remove the chain guard, Safety precautions: step 1, image 2 of 2
    • Make sure the engine is off and cool to the touch before you proceed.
  2. Remove the chain guard: step 2, image 1 of 1
    • Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
  3. Remove the chain guard: step 3, image 1 of 2 Remove the chain guard: step 3, image 2 of 2
    • Flip the gas shutoff switch next to the motor to the left into the off position.
  4. Remove the chain guard: step 4, image 1 of 2 Remove the chain guard: step 4, image 2 of 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  5. Remove the chain guard, Unbolt the cutter blade: step 5, image 1 of 1
    • Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the left side of the machine.
    • You may need to use a 1/2 inch wrench in combination with the socket wrench to hold the nuts in place.
  6. Remove the chain guard: step 6, image 1 of 1
    • Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the right side of the machine.
  7. Remove the chain guard, Remove the cutter blade: step 7, image 1 of 3 Remove the chain guard, Remove the cutter blade: step 7, image 2 of 3 Remove the chain guard, Remove the cutter blade: step 7, image 3 of 3
    • Slide the cutter blade out from under the machine to remove it.
    • Do not handle the blade from the cutting edge.
  8. Remove the chain guard, Remove the chain guard: step 8, image 1 of 1
    • Use a 1/2 inch socket to remove the 130 mm-long bolt securing the chain guard.
  9. Remove the chain guard: step 9, image 1 of 1
    • Carefully tilt the sod cutter on its side.
    • Use a 9/16 inch socket to remove the nut securing the chain guard.
  10. Remove the chain guard: step 10, image 1 of 3 Remove the chain guard: step 10, image 2 of 3 Remove the chain guard: step 10, image 3 of 3
    • Remove the chain guard.
Finish Line
Sam Omiotek
83,715 Reputation
290 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 28
