Removing Bottom of iMac G4 15" 700 MHz EMC 1873
Elliot Freerks
Elliot Freerks and 6 other contributors
Last updated on May 16, 2024
10 - 20 minutes
Easy
Introduction
Go to step 1
We will unscrew the bottom faceplate, then remove the base to access the internal components.
Tools
Show more…
  1. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Outer Base Plate: step 1, image 1 of 2 Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Outer Base Plate: step 1, image 2 of 2
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: step 2, image 1 of 1
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, RAM DIMM: step 3, image 1 of 2 Removing Bottom of iMac G4 15" 700 MHz EMC 1873, RAM DIMM: step 3, image 2 of 2
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
  4. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, AirPort Card: step 4, image 1 of 1
    • Use a spudger to lift and remove the AirPort's antenna connector.
    • This step is only applicable to iMacs that came with an AirPort card installed.
  5. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Removing the Lower Case: step 5, image 1 of 1
    • Remove the four 28.07mm Torx #15 screws from the lower case.
  6. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: step 6, image 1 of 2 Removing Bottom of iMac G4 15" 700 MHz EMC 1873: step 6, image 2 of 2
    • Open the base by carefully pulling straight off, do not rotate the cover.
    • Open slowly to ensure that no cables are damaged or disconnected.
  7. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: step 7, image 1 of 1
    • Squeeze the small black tab and wiggle gently to remove the colored power cable.
    • Do not pull directly on the colored wires.
    • Do not remove black grounding wire.
  8. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: step 8, image 1 of 1
    • Grab both sides of the blue connector and firmly pull to remove it from the mother board.
    • Do not pull directly on the ribbon cable.
10 other people completed this guide.
Elliot Freerks
923 Reputation
3 Guides authored
Cal Poly, Team 5-32, Amido Fall 2011 Member of Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
4 Members
16 Guides authored
1 Guide Comment
Do I need to apply thermal paste? Or it is not necessary?
willynanita - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 48
All Time: 6,613
