Removing Dell Inspiron 1150 Battery
  1. Removing Dell Inspiron 1150 Battery, Removing Dell Inspiron 1150 Battery: step 1, image 1 of 3 Removing Dell Inspiron 1150 Battery, Removing Dell Inspiron 1150 Battery: step 1, image 2 of 3 Removing Dell Inspiron 1150 Battery, Removing Dell Inspiron 1150 Battery: step 1, image 3 of 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
Finish Line
6 other people completed this guide.
Teja
98 Reputation
3 Guides authored
Cal Poly, Team 16-2, Maness Spring 2010 Member of Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 10,879
