Removing Dell Inspiron 1150 Mini Wireless PCI Card
  1. Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: step 1, image 1 of 3 Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: step 1, image 2 of 3 Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: step 1, image 3 of 3
    • Turn the laptop upside down and locate the panel labeled C.
    • Unscrew the single screw holding the cover in place.
    • Lift up the cover and remove it to expose the Wireless MiniPCI Card.
  2. Removing Dell Inspiron 1150 Mini Wireless PCI Card: step 2, image 1 of 2 Removing Dell Inspiron 1150 Mini Wireless PCI Card: step 2, image 2 of 2
    • Using a plastic spudger or similar, gently pry the grey and black wires off.
    • The grey and black wires are the antenna wires so be careful not to damage them
    • Gently pull the retaining clips away from the board so that the board pops up.
  3. Removing Dell Inspiron 1150 Mini Wireless PCI Card: step 3, image 1 of 1
    • Lift the board up and out of the mini PCI slot at an angle of about 35 - 45 degrees
Teja
98 Reputation
3 Guides authored
Cal Poly, Team 16-2, Maness Spring 2010 Member of Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 5,927
