Removing HP Compaq dx2000MT CPU Cooler
  1. Removing HP Compaq dx2000MT CPU Cooler, Removing the HP Compaq dx2000MT Case Doors: step 1, image 1 of 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing HP Compaq dx2000MT CPU Cooler: step 2, image 1 of 2 Removing HP Compaq dx2000MT CPU Cooler: step 2, image 2 of 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing HP Compaq dx2000MT CPU Cooler: step 3, image 1 of 3 Removing HP Compaq dx2000MT CPU Cooler: step 3, image 2 of 3 Removing HP Compaq dx2000MT CPU Cooler: step 3, image 3 of 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing HP Compaq dx2000MT CPU Cooler: step 4, image 1 of 3 Removing HP Compaq dx2000MT CPU Cooler: step 4, image 2 of 3 Removing HP Compaq dx2000MT CPU Cooler: step 4, image 3 of 3
    • Once again, this may take considerable force.
  5. Removing HP Compaq dx2000MT CPU Cooler, Removing HP Compaq dx2000MT CPU Cooler: step 5, image 1 of 2 Removing HP Compaq dx2000MT CPU Cooler, Removing HP Compaq dx2000MT CPU Cooler: step 5, image 2 of 2
    • Remove the 3 pin power connector by pulling it towards the side of the device.
  6. Removing HP Compaq dx2000MT CPU Cooler: step 6, image 1 of 2 Removing HP Compaq dx2000MT CPU Cooler: step 6, image 2 of 2
    • Unscrew the 4 Torx T15 screws holding the CPU Cooler in place.
    • Make sure to hold your cpu cooler when removing the screws. You don't want it to fall!
  7. Removing HP Compaq dx2000MT CPU Cooler: step 7, image 1 of 2 Removing HP Compaq dx2000MT CPU Cooler: step 7, image 2 of 2
    • Remove the cpu cooler by pulling out towards the side of the device.
    • Make sure you do not touch where the cpu cooler makes contact with the processor! You could contaminate the layer of thermal paste that separates these components.
    • When replacing your cpu cooler, make sure you clean the processor contact area on the cooler and processor with isopropyl rubbing alcohol.
2 other people completed this guide.
Logan Pace
2,251 Reputation
9 Guides authored
Cal Poly, Team 17-16, Regan Fall 2011 Member of Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Members
17 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 5,509
