Removing HP Compaq dx2000MT Case Fan
  1. Removing HP Compaq dx2000MT Case Fan, Removing the HP Compaq dx2000MT Case Doors: step 1, image 1 of 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing HP Compaq dx2000MT Case Fan: step 2, image 1 of 2 Removing HP Compaq dx2000MT Case Fan: step 2, image 2 of 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing HP Compaq dx2000MT Case Fan: step 3, image 1 of 3 Removing HP Compaq dx2000MT Case Fan: step 3, image 2 of 3 Removing HP Compaq dx2000MT Case Fan: step 3, image 3 of 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing HP Compaq dx2000MT Case Fan: step 4, image 1 of 3 Removing HP Compaq dx2000MT Case Fan: step 4, image 2 of 3 Removing HP Compaq dx2000MT Case Fan: step 4, image 3 of 3
    • Once again, this may take considerable force.
  5. Removing HP Compaq dx2000MT Case Fan, Case Fan: step 5, image 1 of 3 Removing HP Compaq dx2000MT Case Fan, Case Fan: step 5, image 2 of 3 Removing HP Compaq dx2000MT Case Fan, Case Fan: step 5, image 3 of 3
    • Remove the 3 prong power connector from the motherboard by pulling it outwards toward the side of the device.
  6. Removing HP Compaq dx2000MT Case Fan: step 6, image 1 of 3 Removing HP Compaq dx2000MT Case Fan: step 6, image 2 of 3 Removing HP Compaq dx2000MT Case Fan: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the 4 push fasteners from the case by:
    • Prying them outwards with a small flathead screwdriver and
    • Pulling them out with tweezers or plyers.
  7. Removing HP Compaq dx2000MT Case Fan: step 7, image 1 of 3 Removing HP Compaq dx2000MT Case Fan: step 7, image 2 of 3 Removing HP Compaq dx2000MT Case Fan: step 7, image 3 of 3
    • Remove the fan from the case by pulling it towards the front of the device.
3 other people completed this guide.
Logan Pace
2,251 Reputation
9 Guides authored
Cal Poly, Team 17-16, Regan Fall 2011 Member of Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Members
17 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 2,745
