Removing HP Compaq dx2000MT Power Supply
  1. Removing HP Compaq dx2000MT Power Supply, Removing the HP Compaq dx2000MT Case Doors: step 1, image 1 of 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing HP Compaq dx2000MT Power Supply: step 2, image 1 of 2 Removing HP Compaq dx2000MT Power Supply: step 2, image 2 of 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing HP Compaq dx2000MT Power Supply: step 3, image 1 of 3 Removing HP Compaq dx2000MT Power Supply: step 3, image 2 of 3 Removing HP Compaq dx2000MT Power Supply: step 3, image 3 of 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing HP Compaq dx2000MT Power Supply: step 4, image 1 of 3 Removing HP Compaq dx2000MT Power Supply: step 4, image 2 of 3 Removing HP Compaq dx2000MT Power Supply: step 4, image 3 of 3
    • Once again, this may take considerable force.
  5. Removing HP Compaq dx2000MT Power Supply, Power Supply: step 5, image 1 of 3 Removing HP Compaq dx2000MT Power Supply, Power Supply: step 5, image 2 of 3 Removing HP Compaq dx2000MT Power Supply, Power Supply: step 5, image 3 of 3
    • Remove the 4 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
  6. Removing HP Compaq dx2000MT Power Supply: step 6, image 1 of 2 Removing HP Compaq dx2000MT Power Supply: step 6, image 2 of 2
    • Remove the 20 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
  7. Removing HP Compaq dx2000MT Power Supply: step 7, image 1 of 3 Removing HP Compaq dx2000MT Power Supply: step 7, image 2 of 3 Removing HP Compaq dx2000MT Power Supply: step 7, image 3 of 3
    • Remove the 4 Torx T15 screws from the rear of the power supply
  8. Removing HP Compaq dx2000MT Power Supply: step 8, image 1 of 2 Removing HP Compaq dx2000MT Power Supply: step 8, image 2 of 2
    • Slide the power supply towards the front of the device
    • Keep your hand underneath it! You don't want to drop it!
    • Then pull the power supply down and remove it from the case.
8 other people completed this guide.
Logan Pace
2,251 Reputation
9 Guides authored
Cal Poly, Team 17-16, Regan Fall 2011 Member of Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Members
17 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 28
All Time: 3,437
