Removing Lenovo Thinkpad T61p RAM
  1. Removing Lenovo Thinkpad T61p RAM, RAM: step 1, image 1 of 2 Removing Lenovo Thinkpad T61p RAM, RAM: step 1, image 2 of 2
    • Place the laptop on a fat surface with the underside facing up
    • Remove the 4 Philips head screws.
    • Turn the computer over and open the display
    • Grasping each side of the palm rest, gently lift it off and rotate toward the front of the laptop
    • The palm rest will be connected to the main board by a ribbon cable
  2. Removing Lenovo Thinkpad T61p RAM: step 2, image 1 of 1
    • Disconnect the touchpad ribbon cable
    • This step is recommended in the service manual however it is possible to remove the RAM without discoinnecting the touchpad cable
  3. Removing Lenovo Thinkpad T61p RAM: step 3, image 1 of 1
    • Locate the RAM modules
    • Gently press the metal tabs outwards to release the top RAM module and remove it from the laptop
    • With the top RAM module removed you can release the lower RAM module in the same manner.
5 other people completed this guide.
Glac1er
180 Reputation
1 Guide authored
Glac1er Member of Glac1er
Community
1 Member
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 9,977
