Removing Nikon Coolpix 4600 Front and Rear case
  1. Removing Nikon Coolpix 4600 Front and Rear case, Front and Rear Case: step 1, image 1 of 2 Removing Nikon Coolpix 4600 Front and Rear case, Front and Rear Case: step 1, image 2 of 2
    • Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right).
    • Using a Phillips 00 screwdriver, remove all of the six screws.
  2. Removing Nikon Coolpix 4600 Front and Rear case: step 2, image 1 of 2 Removing Nikon Coolpix 4600 Front and Rear case: step 2, image 2 of 2
    • Carefully pull the front and back case apart.
    • The front case is attached to internal components and cannot be removed independently.
  3. Removing Nikon Coolpix 4600 Front and Rear case: step 3, image 1 of 1
    • Look closely at the connection between the ribbon cable and the motherboard. Locate the two grey tabs on either side of the connecting bracket.
    • Slide the grey tabs toward the bottom of camera. Gently disconnect the ribbon cable from the motherboard.
    • After disconnecting the data ribbon, you can now separate the back case from the front case.
Nathan Sperling
119 Reputation
4 Guides authored
Cal Poly, Team 9-43, Regan Spring 2012 Member of Cal Poly, Team 9-43, Regan Spring 2012
CPSU-REGAN-S12S9G43
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 1,532
