Removing Saeco Vienna Sup 018 Top Cover
  1. Removing Saeco Vienna Sup 018 Top Cover, Removing Saeco Vienna Sup 018 Top Cover: step 1, image 1 of 1
    • Never forget: Pull the plug out!
    • Remove all attachments such as drawers, water tank, brewing unit.
    • Carefully pull the steam button out. If it is too tight, first loosen the cover (steps 2 to 4), lift slightly and then push the ratchet nose with a small screwdriver.
  2. Removing Saeco Vienna Sup 018 Top Cover: step 2, image 1 of 1
    • The bean container is fixed with two Phillipps screws. Unscrew those.
    • The adjusters of the grinder and the quantity of coffee (if present) can remain.
    • Lift the bean container up und remove it from the device.
  3. Removing Saeco Vienna Sup 018 Top Cover: step 3, image 1 of 3 Removing Saeco Vienna Sup 018 Top Cover: step 3, image 2 of 3 Removing Saeco Vienna Sup 018 Top Cover: step 3, image 3 of 3
    • Remove the single T10 Torx screw on the rear edge of the top cover under the water reservoir.
    • Remove the single Phillipps screw on the rear edge of the top cover under the container of the coffee beans.
    • There are two Phillipps screws on the frontal unterside edge of the top cover. Turn them out.
  4. Removing Saeco Vienna Sup 018 Top Cover: step 4, image 1 of 1
    • Now the cover can be lifted off. Pull backwards, then diagonally forward. Remove the silicone hose from the water tank.
Special thanks to these translators:
de en
100%
VauWeh is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
210,196 Reputation
255 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
26 Members
1,186 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 21
All Time: 1,361
