Removing and replacing keys
  1. Tool used on this step:
    Buy
    • The key cap should be lifted from the top edge. You can use any "tool" that allows you to get under the top edge, and lift the edge away. Something flat and relatively thin will do (like a small flat-head screw driver). In this video I am using some tweezers.
    • Removing the key cap from the top edge should result in the 2-piece key armature remaining attached to the keyboard. This is the ideal situation, because it is easy to then replace the key cap once you blow out any dirt that was under the key.
    • If one or both parts of the armature detach along with the key cap, we'll address that below.
  2. Removing and replacing keys, (REFERENCE) Cap removed, armature still in place: step 2, image 1 of 2 Removing and replacing keys, (REFERENCE) Cap removed, armature still in place: step 2, image 2 of 2
    • These photos are to give you a reference for what it looks like when the armature is correctly in place. This may be helpful if you removed the armature and need to get it back in correctly.
  3. Removing and replacing keys, (REFERENCE) Cap and armature removed: step 3, image 1 of 2 Removing and replacing keys, (REFERENCE) Cap and armature removed: step 3, image 2 of 2
    • This is just a visual reference showing the armature removed.
  4. Removing and replacing keys, (REFERENCE) The armature correctly pieced together: step 4, image 1 of 3 Removing and replacing keys, (REFERENCE) The armature correctly pieced together: step 4, image 2 of 3 Removing and replacing keys, (REFERENCE) The armature correctly pieced together: step 4, image 3 of 3
    • If you removed the key cap from the top edge first, the armature should have remained attached to the keyboard. This is the ideal situation (unless you need to remove the armature to clear something from it, in which case you'll likely need to remove it).
    • WHAT IF — perhaps like me, you may have attempted removing a key cap without instructions, and you didn't do it from the top edge. In which case, it's quite likely the armature came out, and may have come apart (it has two parts).
    • These photos show you what the armature should look like when correctly pieced together as one articulating component.
    • The armature should be pieced together as one component. See photos in previous step for how it will look when correctly pieced together.
    • The armature attaches in two locations. At the bottom edge, and at the top edge. You need to install the armature from the bottom edge first. There are tiny metal hooks toward the centre of the bottom edge, and there are two tiny hooks at each corner along the top edge.
    • You need to slide the bottom edge of the armature under the hooks so that the two holes in the armature get hooked onto the keyboard.
    • Then drop the top edge down onto the keyboard, and gently push the top left and top right corners so they click onto the small metal hooks in those locations.
    • The armature should now be reattached. Test it to ensure it's attached.
    • This video shows how to simply click the key caps back into position.
    • THIRD KEY IN VIDEO: You may be tempted to install the armature under the key cap first, and then try to install the keycap AND armature onto the keyboard at once. This typically doesn't work so well, as shown at the end of the video.
Keycap puller is optional. Decent tweezers do the job nicely.
Inspired Earth
325 Reputation
1 Guide authored
3 Guide Comments
I have tried to reassemble keys by myself, and while standard keys were relatively easy to figure out, I got stuck at the spacebar. I made a few rookie mistakes, and now I have a perfectly functioning keyboard...without a spacebar. The logic is similar to the spacebar on Apple keyboards, but the armature part is a bit different. Now my spacebar has broken plastic elements used to hook the armature. And Satechi does not offer replacement keys. So I am writing this hoping someone can save themselves the pain of 1 broken key.
Don't be like me and do some research before reassembling your Satechi keyboard.
D_S - Reply
Hi, does anyone know where to get a single replacement armature for a key of the Satechi keyboard?
Freeness2359 - Reply
Unfortunately a tea or coffee was spilled on mine, not sure if this keyboard is glued together otherwise i could have cleaned it up and make the self press fixed. I have SATECHI ST-AMWK
max - Reply
Past 24 Hours: 6
Past 7 Days: 47
Past 30 Days: 245
All Time: 7,555
