Removing the Back Panel
  1. Removing the Back Panel, Removing the Back Panel: step 1, image 1 of 3 Removing the Back Panel, Removing the Back Panel: step 1, image 2 of 3 Removing the Back Panel, Removing the Back Panel: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Removing the Back Panel: step 2, image 1 of 3 Removing the Back Panel: step 2, image 2 of 3 Removing the Back Panel: step 2, image 3 of 3
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 29
All Time: 2,806
