Removing the Behringer Eurolive B212D Electronics Box
Troy W. Weber
Troy W. Weber and 6 other contributors
Last updated on May 1, 2022
5 - 10 minutes
Easy
Community-Contributed Guide
Introduction
Go to step 1
Your B212D contains a case filled with a metal box that contains all the electronics, except for the speakers. You will be removing this electronics box to access the case's internal space - you know, in case you need to stash $1,000,000 dollars in there to hide it from the CIA! :)
iFixit earns commission when you buy through these links.
  1. Removing the Behringer Eurolive B212D Electronics Box, Removing the Behringer Eurolive B212D Electronics Box: step 1, image 1 of 1
    • CAUTION: Unplug your speaker from the power outlet.
    • Remove the 8 Phillips screws from the back of the speaker.
  2. Removing the Behringer Eurolive B212D Electronics Box: step 2, image 1 of 1
    • Carefully remove the back panel, lifting out the metal electronics-box with it.
    • To avoid damaging your speaker, remove slowly, as there is still a wire attached from the electronics box to the speaker.
4 other people completed this guide.
Troy W. Weber
1,449 Reputation
6 Guides authored
2 Guide Comments
I want to buy the hole back panel, but I don't where?, tell me
miguelangelvera63 - Reply
I will wait for answer
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 27
All Time: 3,675
