Removing the Dell Inspiron 1150 Keyboard
  1. Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: step 1, image 1 of 3 Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: step 1, image 2 of 3 Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: step 1, image 3 of 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Keyboard, Keyboard: step 2, image 1 of 3 Removing the Dell Inspiron 1150 Keyboard, Keyboard: step 2, image 2 of 3 Removing the Dell Inspiron 1150 Keyboard, Keyboard: step 2, image 3 of 3
    • Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
    • You need to lay the LCD screen down flat to allow the hinge cover to be lifted off
    • Lift the hinge cover off and set aside
  3. Removing the Dell Inspiron 1150 Keyboard: step 3, image 1 of 3 Removing the Dell Inspiron 1150 Keyboard: step 3, image 2 of 3 Removing the Dell Inspiron 1150 Keyboard: step 3, image 3 of 3
    • Remove 4ea M2 x 3mm keyboard screws
    • Lift up keyboard from the rear to expose the connector below
    • Disconnect the keyboard ribbon cable from the mother board
Richdave
32,254 Reputation
30 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,516 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 886
