Removing the Dell Inspiron 1150 Modem Card
  1. Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: step 1, image 1 of 3 Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: step 1, image 2 of 3 Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: step 1, image 3 of 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Modem Card, Modem Card: step 2, image 1 of 3 Removing the Dell Inspiron 1150 Modem Card, Modem Card: step 2, image 2 of 3 Removing the Dell Inspiron 1150 Modem Card, Modem Card: step 2, image 3 of 3
    • Turn the laptop upside down and locate the panel labeled C
    • Unscrew the single screw holding the cover in place.
    • Lift up the cover and remove it to expose the Modem Card.
  3. Removing the Dell Inspiron 1150 Modem Card: step 3, image 1 of 2 Removing the Dell Inspiron 1150 Modem Card: step 3, image 2 of 2
    • Locate the Modem card.
    • Remove the screws.
  4. Removing the Dell Inspiron 1150 Modem Card: step 4, image 1 of 2 Removing the Dell Inspiron 1150 Modem Card: step 4, image 2 of 2
    • Pull tab to lift the card out of the connector on the main board.
    • Disconnect the cable attached to the left edge of the Modem card
Finish Line
Lauren
4 Reputation
2 Guides authored
Cal Poly, Team 16-2, Maness Spring 2010 Member of Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 4,529
