Removing the HP Elitebook 6930p Bluetooth module
  1. Removing the HP Elitebook 6930p Bluetooth module, Battery Removal: step 1, image 1 of 3 Removing the HP Elitebook 6930p Bluetooth module, Battery Removal: step 1, image 2 of 3 Removing the HP Elitebook 6930p Bluetooth module, Battery Removal: step 1, image 3 of 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Bluetooth module, Bluetooth module: step 2, image 1 of 3 Removing the HP Elitebook 6930p Bluetooth module, Bluetooth module: step 2, image 2 of 3 Removing the HP Elitebook 6930p Bluetooth module, Bluetooth module: step 2, image 3 of 3
    • Locate the Bluetooth module cover on the bottom of the laptop
    • Loosen the M2.0×5.0 captive screw and remove the cover by by lifting it straight up
    • The Bluetooth module is connected to the laptop via a small cable with very fine wires - take care not to damage the cable when you pull the module out of the case.
    • Gently lift the Bluetooth module up and over the retaining clip. A plastic spudger may be useful.
    • Disconnect the connector being careful not to damage the fine wires on the cable.
4 other people completed this guide.
Richdave
32,365 Reputation
30 Guides authored
Master Techs Member of Master Techs
Community
327 Members
1,697 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 5,201
