Removing the Jura IMPRESSA J5 brewing unit (brewgroup)
  1. Removing the Jura IMPRESSA J5 brewing unit (brewgroup), Jura Capresso IMPRESSA J5  opening procedure: step 1, image 1 of 1
    • Unplug the power cord!
    • Remove the water tank and the drip tray. Remove all coffee beans from the storage container.
  2. Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 2, image 1 of 3 Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 2, image 2 of 3 Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 2, image 3 of 3
    • Flip open the lid of the bean compartment.
    • Unscrew the two slotted screws inside the bean compartment. The screws have a rubber washer and will not come out completely.
    • Remove the bean compartment.
  3. Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 3, image 1 of 3 Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 3, image 2 of 3 Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 3, image 3 of 3
    Tool used on this step:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    Buy
    • The top cover is fastened with oval head screws. Unscrew them.
    • These screws have an oval head that makes them look like rivets (picture 2). You need to use a special bit - also available at iFixit - for their removal. Here a DIY guide. If the right bit is not available, it could be done with a pair of needle nose pliers. Jura wants to keep us out of our own machines!!!
  4. Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 4, image 1 of 1
    • Also remove the two oval head screws underneath the ground coffee compartment lid.
  5. Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 5, image 1 of 1
    • Now you can pry up the top cover all around.
    • Remove the top cover. This often requires a little force.
    • Use plastic tools to avoid scratching your device.
  6. Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 6, image 1 of 2 Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 6, image 2 of 2
    • Turn the device with the back facing you.
    • Turn the Jura label a few degrees counterclockwise. If it's hard to do, use a small suction cup.
    • Remove the Jura label.
  7. Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 7, image 1 of 3 Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 7, image 2 of 3 Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 7, image 3 of 3
    • Underneath the label you will find two Torx T15 screws. Remove them.
    • Carefully pull the top of the chrome cover slightly outwards, then push it down and put it aside.
  8. Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 8, image 1 of 1
    • Remove the Torx T15 screw on the side panel with the water tank.
  9. Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 9, image 1 of 2 Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 9, image 2 of 2
    • Pull the right side panel slightly towards the back.
    • Remove the side panel.
  10. Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 10, image 1 of 1
    • Pull the left side panel slightly towards the back and remove it.
  11. Removing the Jura IMPRESSA J5 brewing unit (brewgroup), Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 11, image 1 of 2 Removing the Jura IMPRESSA J5 brewing unit (brewgroup), Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 11, image 2 of 2
    • The brewing unit is on the left side of the machine.
  12. Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 12, image 1 of 2 Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 12, image 2 of 2
    • The cover over the brewing unit is only lightly gripped. Lift it out.
  13. Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 13, image 1 of 1
    • In this image the brewing unit has been removed already to show you how it is connected.
    • Two Torx T15 machine screws
    • One Torx T15 screw
    • The hot water connection is plugged in.
    • The hose for the coffee spout is connected above.
  14. Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 14, image 1 of 1
    • Unscrew the two Torx T15 machine screws.
    • Unscrew the lower Torx T15 screw near the hot water inlet pipe.
    • Pull off the coffee dispensing pipe.
  15. Removing the Jura IMPRESSA J5 brewing unit (brewgroup): step 15, image 1 of 1
    • First pull the brewing unit outward slightly at the base, lift it out with a downward motion.
    • If you want to disassemble the brewing unit for maintenance or cleaning, use these oder these instructions.
Work your way through the instructions in reverse to re-assemble the device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
212,808 Reputation
265 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
27 Members
1,209 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 47
All Time: 4,833
