Replacing the SSD
  1. Replacing the SSD, Battery: step 1, image 1 of 3 Replacing the SSD, Battery: step 1, image 2 of 3 Replacing the SSD, Battery: step 1, image 3 of 3
    • Unlock the battery latch on the right.
    • Unlock the battery lock on the left.
    • Remove the battery pack from its slot.
  2. Replacing the SSD, Access to Components 2: step 2, image 1 of 3 Replacing the SSD, Access to Components 2: step 2, image 2 of 3 Replacing the SSD, Access to Components 2: step 2, image 3 of 3
    • Using the Philips # 0 screwdriver, unscrew the 2 screws of the top cover
    • Check the marks indicating the direction in which the cover must be removed.
    • Remove the bottom cover by removing it in the direction of the markers.
  3. Replacing the SSD: step 3, image 1 of 1
    • Then appear the other components of the Laptop.
  4. Replacing the SSD, SSD disk: step 4, image 1 of 3 Replacing the SSD, SSD disk: step 4, image 2 of 3 Replacing the SSD, SSD disk: step 4, image 3 of 3
    • This is the SSD drive
    • Unscrew the fixing screw of the SSD using the Philips # 0 screwdriver.
    • Remove the SSD.
  5. Replacing the SSD: step 5, image 1 of 1
    • Here is the SSD drive out of its slot.
For reassembly, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,538 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 34
All Time: 1,719
