Repairing Apex Tablet 7 Internal Speaker Replacement
  1. Repairing Apex Tablet 7 Internal Speaker Replacement, Back Panel: step 1, image 1 of 1
    • Unscrew the two 2.70 mm Phillips #00 screws on the side of the tablet that has the buttons and the headphone jack (bottom side when holding upright).
  2. Repairing Apex Tablet 7 Internal Speaker Replacement: step 2, image 1 of 2 Repairing Apex Tablet 7 Internal Speaker Replacement: step 2, image 2 of 2
    • CAUTION: When removing the back panel of the tablet, take caution around the speaker. This is located in the lower right corner when looking at the back of the tablet. There are two wires inside connecting the tablet back panel to the device itself and this connection may be severed if the back is pulled off without care.
    • This connection is shown in red on the pictures.
  3. Repairing Apex Tablet 7 Internal Speaker Replacement: step 3, image 1 of 2 Repairing Apex Tablet 7 Internal Speaker Replacement: step 3, image 2 of 2
    • Slide a plastic opening tool in between the edge of the back panel and the the top edge of the device.
    • Run the plastic opening tool along the sides of the tablet while keeping it in the crack between the tablet and the back panel to create an opening.
  4. Repairing Apex Tablet 7 Internal Speaker Replacement: step 4, image 1 of 1
    • Apply pressure using your hand to pop the back panel off slowly, taking extra care around the speaker connection.
  5. Repairing Apex Tablet 7 Internal Speaker Replacement: step 5, image 1 of 1
    • The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
  6. Repairing Apex Tablet 7 Internal Speaker Replacement, Internal Speaker: step 6, image 1 of 3 Repairing Apex Tablet 7 Internal Speaker Replacement, Internal Speaker: step 6, image 2 of 3 Repairing Apex Tablet 7 Internal Speaker Replacement, Internal Speaker: step 6, image 3 of 3
    • If wires to the speaker have become severed or damaged they will need to be repaired. Locate any damage to these wires. (The connection to the circuit board is commonly broken by removing the back panel.)
    • Locate the soldering points where the wires were originally connected.
    • Plug in your soldering iron and wait for it to heat up.
  7. Repairing Apex Tablet 7 Internal Speaker Replacement: step 7, image 1 of 2 Repairing Apex Tablet 7 Internal Speaker Replacement: step 7, image 2 of 2
    • Make sure the soldering iron is hot enough to melt solder, and prepare your soldering station.
    • You can make sure your iron is hot enough by touching the end of your roll of solder to the soldering iron tip.
    • Get a wet sponge or wet paper towel ready to wipe debris from the soldering iron tip.
    • If available, have a desoldering braid nearby to absorb excess solder blobs.
  8. Repairing Apex Tablet 7 Internal Speaker Replacement: step 8, image 1 of 2 Repairing Apex Tablet 7 Internal Speaker Replacement: step 8, image 2 of 2
    • Solder the red wire to the location noted here.
    • You may need to replace or shorten your wire in order to make this connection.
    • If this wire is damaged or too short, a new wire will have to be soldered at the speaker and the circuit board.
    • CAUTION: The soldering iron is hot and can melt/burn-out other components on the tablet. Avoid applying heat to any part of the tablet for extended amounts of time.
  9. Repairing Apex Tablet 7 Internal Speaker Replacement: step 9, image 1 of 3 Repairing Apex Tablet 7 Internal Speaker Replacement: step 9, image 2 of 3 Repairing Apex Tablet 7 Internal Speaker Replacement: step 9, image 3 of 3
    • Following the same precautions as with the red wire, solder the black wire to the location noted here.
Corrine Nief
316 Reputation
2 Guides authored
Baylor, Team 2-2, Grigsby Spring 2015 Member of Baylor, Team 2-2, Grigsby Spring 2015
BU-GRIGSBY-S15S2G2
4 Members
10 Guides authored
2 Comments
i lost an internal speaker for the zeepad i was repairing. is there a way to get replacement parts for this type of thing or do i just throw it away?
scott - Reply
i replaced a cracked screen on a zeepad 7.0. the screen is great but i misplaced the speaker and battery assembly that sat on the back plate. can i get replacement parts for something like this, or do i just toss it in the trash?
scott - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 933
