Repairing Black and Decker 9074 Screwdriver  Battery
oldturkey03
oldturkey03 and 5 other contributors
Last updated on March 31, 2023
30 minutes
Moderate
Featured Guide
Community-Contributed Guide
Introduction
Go to step 1
Here I am rebuilding, actually more building, a battery of the electric screw driver. The original battery is no longer available so I decided to build my own i order to continue to use the screwdriver. The battery cell I am using are 4/5 SC (sub C) size. Meaning they are 4/5 the size of a C-Cell. They are 23 x 34 mm in size with a capacity of 2000mAh and 1.2 Volts.
  1. Repairing Black and Decker 9074 Screwdriver  Battery, Repairing Black and Decker 9074 Screwdriver  Battery: step 1, image 1 of 3 Repairing Black and Decker 9074 Screwdriver  Battery, Repairing Black and Decker 9074 Screwdriver  Battery: step 1, image 2 of 3 Repairing Black and Decker 9074 Screwdriver  Battery, Repairing Black and Decker 9074 Screwdriver  Battery: step 1, image 3 of 3
    • Here is the original battery. Three cells surrounded by a soft plastic sheathing
    • Cut the plastic (I used a utility knife) away.
    • Now the three cells are clearly visible and the way they are connected in series. Meaning positive from one cell to negative on the next cell. Each cell separated by a rubber insulator
  2. Repairing Black and Decker 9074 Screwdriver  Battery: step 2, image 1 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 2, image 2 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 2, image 3 of 3
    • Top to bottom on this image shows the insulator that is on the top portion of the cells. Next are the old three cells and bottom the new cells.
    • The contacts on the old cells appear to be spot welded to make the connection.
    • Separate the connections with either a pair of side cutters or a pair of scissor. This will allow you to remove the insulators.
  3. Repairing Black and Decker 9074 Screwdriver  Battery: step 3, image 1 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 3, image 2 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 3, image 3 of 3
    • Here all the cells are separated and the insulator removed
    • Plenty of corrosion visible on each of the old cells.
    • To prepare the new cells, the heatshrink insulation from the contacts need to be removed. I used a utility knife to remove that.
  4. Repairing Black and Decker 9074 Screwdriver  Battery: step 4, image 1 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 4, image 2 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 4, image 3 of 3
    • Here is the first cell, insulation removed. Prepare all cells like that.
    • Align the positive contact of the first cell with the negative contact of the second cell.
    • Since the contacts will be soldered to each other, I did use some flux on the contacts prior to soldering.
  5. Repairing Black and Decker 9074 Screwdriver  Battery: step 5, image 1 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 5, image 2 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 5, image 3 of 3
    • Apply the flux to the contacts, in my case I used a cotton swab.
    • Once proper alignment is obtained, I use a alligator clip to hold them in position.
    • Now solder the contacts together. I used a 30watt soldering iron with a blunt tip.
  6. Repairing Black and Decker 9074 Screwdriver  Battery: step 6, image 1 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 6, image 2 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 6, image 3 of 3
    • Here is the first attempt. Luckily I noticed that I had forgotten to install the rubber insulator before going on to the next cell. Desolder the contacts to rectify this.
    • Here is the next cell properly prepared.
    • First two cells, separated by the insulator, soldered together.
  7. Repairing Black and Decker 9074 Screwdriver  Battery: step 7, image 1 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 7, image 2 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 7, image 3 of 3
    • 2nd and 3rd cell prepared and being aligned.
    • Applied flux and alligator clip to hold it in alignment.
    • Solder the contacts together
  8. Repairing Black and Decker 9074 Screwdriver  Battery: step 8, image 1 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 8, image 2 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 8, image 3 of 3
    • All three cells soldered together, positive to negative end, creating a series connection.
    • The original battery was wrapped in some soft plastic. I decided to use 1 1/4 inch heat shrink tubing. Black electric tape might work just as well, but I used what I had on hand.
    • Heatshrink tubing placed over the cells
  9. Repairing Black and Decker 9074 Screwdriver  Battery: step 9, image 1 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 9, image 2 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 9, image 3 of 3
    • I placed a clamp from end to end. This will prevent any exposure to hot parts, will allow movement of the battery and still maintain alignment.
    • Here is the two speed heatgun I use for my projects.
    • Simply apply constant heat to the tubing by moving the heatgun along the heatshrink tubing.
  10. Repairing Black and Decker 9074 Screwdriver  Battery: step 10, image 1 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 10, image 2 of 3 Repairing Black and Decker 9074 Screwdriver  Battery: step 10, image 3 of 3
    • Here is the battery with the heatshrink tubing attached.
    • Obviously the contacts are being than the connector. (The corrosion visible on the connector was cleaned of during the installation)
    • Trim the contacts with either a pair of sidecutters, or like in my case, use a pair of scissors.
  11. Repairing Black and Decker 9074 Screwdriver  Battery: step 11, image 1 of 1
    • Once the contacts are trimmed to size, the battery is ready for installation into the screwdriver. There is a separate guide for that. Total cost for this was around $9.00 for the cells.
    Excellent guide. Very useful for guys who try to maintain old stuff.Simple step by step description and picturisation. Hats off to you for the painstaking work.
    Ramakanth Mani - Reply
7 other people completed this guide.
oldturkey03
813,468 Reputation
119 Guides authored
Global Fixers Member of Global Fixers
Community
45 Members
702 Guides authored
3 Comments
What are the specs on the batteries, and where did you get them? I don’t see any on mine. Thanks!
TerryG - Reply
eBay has the exact set the 4/5 sc sub c are the shorter ones easy to find with connecters already on each end of battery I'm rebuilding mine soon as they come in I'll post results
Corey Coker -
Thanks for the instructions.. Just a small point, when applying the heat gun (for thermal shrinking application) I think you better tell to use insulators or some kind of n insulation for the metal clamp, to avoid short circuit.. But thanks for all this anyways…
facehobi - Reply
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 61
All Time: 9,101
