Repairing EPSON B-510DN Error 0xF2 or 0xF3
  1. Repairing EPSON B-510DN Error 0xF2 or 0xF3, Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 1, image 1 of 3 Repairing EPSON B-510DN Error 0xF2 or 0xF3, Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 1, image 2 of 3 Repairing EPSON B-510DN Error 0xF2 or 0xF3, Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 1, image 3 of 3
    • Remove the paper tray
    • Remove the paper cassette
    • Remove the ink tanks.
  2. Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 2, image 1 of 2 Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 2, image 2 of 2
    • Remove the opening covers.
  3. Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 3, image 1 of 1
    • Remove the rear component
  4. Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 4, image 1 of 1
    • Dismount the Ink lever
  5. Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 5, image 1 of 2 Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 5, image 2 of 2
    • Remove the front panel screws
  6. Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 6, image 1 of 2 Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 6, image 2 of 2
    • Dismount LCD Panel
  7. Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 7, image 1 of 3 Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 7, image 2 of 3 Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 7, image 3 of 3
  8. Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 8, image 1 of 3 Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 8, image 2 of 3 Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 8, image 3 of 3
    • Remove the back panel screws
  9. Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 9, image 1 of 2 Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 9, image 2 of 2
    • Remove the last back panel screw (hidden behind the LCD display)
  10. Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 10, image 1 of 1
    • Remove the back ethernet panel
  11. Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 11, image 1 of 3 Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 11, image 2 of 3 Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 11, image 3 of 3
    • Remove the main back panel, being careful not to damage the LCD display
  12. Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 12, image 1 of 2 Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 12, image 2 of 2
    • Clean the left roller very gently with a dry tissue or a soft brush
  13. Repairing EPSON B-510DN Error 0xF2 or 0xF3, Clean the right encoder: step 13, image 1 of 3 Repairing EPSON B-510DN Error 0xF2 or 0xF3, Clean the right encoder: step 13, image 2 of 3 Repairing EPSON B-510DN Error 0xF2 or 0xF3, Clean the right encoder: step 13, image 3 of 3
    • Clean the right encoder very gently with a dry tissue or a soft brush.
  14. Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 14, image 1 of 2 Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 14, image 2 of 2
    • If you want to test the printer you need to insert paper, and cover 2 switches with tape.
  15. Repairing EPSON B-510DN Error 0xF2 or 0xF3: step 15, image 1 of 1
    • Reassemble the printer (remove the tape first if you have used it) following these instructions in reverse.
16 other people completed this guide.
delete
541 Reputation
1 Guide authored
14 Comments
It's works, thanks
Thom - Reply
Perfect. I used this guide to disassemble my printer.
I had 0xF1 and/or 0xF4. The reason was some paper stuck between the gears of the paper feed (in this guide step 12).
I hope this hint will help others. I didn't find any info about these error code online.
DumahBrazorf - Reply
Error descriptions I found here - http://www.fatalerrors.info/
John Smith -
Thank you very much ! This is a very useful and beautifully documented guide. Best wishes and greetings to the kind author of this guide from Bratislava, Slovakia.
George Pekarovic
George - Reply
muito obrigado pela ajuda
Filipe Rocha - Reply
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 102
All Time: 60,063
