Repairing HP OfficeJet 3833 Paper Jam
  1. Repairing HP OfficeJet 3833 Paper Jam, Repairing HP OfficeJet 3833 Paper Jam: step 1, image 1 of 2 Repairing HP OfficeJet 3833 Paper Jam, Repairing HP OfficeJet 3833 Paper Jam: step 1, image 2 of 2
    • Remove all paper from the printer.
  2. Repairing HP OfficeJet 3833 Paper Jam: step 2, image 1 of 2 Repairing HP OfficeJet 3833 Paper Jam: step 2, image 2 of 2
    • Check the input tray, located in the back of the printer, for any paper remains and remove them.
  3. Repairing HP OfficeJet 3833 Paper Jam: step 3, image 1 of 2 Repairing HP OfficeJet 3833 Paper Jam: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Check the input tray for any foreign objects.
    • You may need to hold down the input tray and shine a flashlight inside to have a better look.
    • Long tweezers are recommended to remove objects such as thumbnails and tacks.
  4. Repairing HP OfficeJet 3833 Paper Jam: step 4, image 1 of 2 Repairing HP OfficeJet 3833 Paper Jam: step 4, image 2 of 2
    • Check the output tray, located in the front of the printer, for paper remains and remove them.
  5. Repairing HP OfficeJet 3833 Paper Jam: step 5, image 1 of 3 Repairing HP OfficeJet 3833 Paper Jam: step 5, image 2 of 3 Repairing HP OfficeJet 3833 Paper Jam: step 5, image 3 of 3
    • Shut down the printer.
    • Hold down the power button until a message appears.
    • Select the Shut Down option.
    • A message will appear and the printer will turn off.
  6. Repairing HP OfficeJet 3833 Paper Jam: step 6, image 1 of 2 Repairing HP OfficeJet 3833 Paper Jam: step 6, image 2 of 2
    • Unplug the printer power cable from the wall outlet.
    • Remove the power cable from the back of the printer.
  7. Repairing HP OfficeJet 3833 Paper Jam: step 7, image 1 of 3 Repairing HP OfficeJet 3833 Paper Jam: step 7, image 2 of 3 Repairing HP OfficeJet 3833 Paper Jam: step 7, image 3 of 3
    • Pull back on the front sides of the printer to remove the front panel.
    • Then pull the handle inside to remove the ink cartridge panel.
  8. Repairing HP OfficeJet 3833 Paper Jam: step 8, image 1 of 2 Repairing HP OfficeJet 3833 Paper Jam: step 8, image 2 of 2
    • Slide the ink cartridge to the side.
    • This step must be done carefully to prevent damage to the printer.
  9. Repairing HP OfficeJet 3833 Paper Jam: step 9, image 1 of 2 Repairing HP OfficeJet 3833 Paper Jam: step 9, image 2 of 2
    • Search for and remove any debris.
  10. Repairing HP OfficeJet 3833 Paper Jam: step 10, image 1 of 1
    • Put the printer on its side.
    • You may need to open the top half and lay it down to prevent the printer from falling.
  11. Repairing HP OfficeJet 3833 Paper Jam: step 11, image 1 of 2 Repairing HP OfficeJet 3833 Paper Jam: step 11, image 2 of 2
    • Locate the cleanout door on the bottom half of the printer.
    • Open the cleanout door to remove unwanted debris.
Finish Line
Ivory S. Mayorga
193 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 30
All Time: 3,116
