Nokia 6560 keypad replacement or cleaning
  1. Nokia 6560 keypad replacement or cleaning, Battery: step 1, image 1 of 2 Nokia 6560 keypad replacement or cleaning, Battery: step 1, image 2 of 2
    • Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
    • Lift off your cell phone's back cover.
  2. Nokia 6560 keypad replacement or cleaning: step 2, image 1 of 2 Nokia 6560 keypad replacement or cleaning: step 2, image 2 of 2
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove the battery from your cell phone.
  3. Nokia 6560 keypad replacement or cleaning, Keypad: step 3, image 1 of 2 Nokia 6560 keypad replacement or cleaning, Keypad: step 3, image 2 of 2
    • Open the front cover of your cell phone with the plastic opening tool or finger nail.
    • Lift the cover upwards, starting from the bottom below the keypad.
  4. Nokia 6560 keypad replacement or cleaning: step 4, image 1 of 2 Nokia 6560 keypad replacement or cleaning: step 4, image 2 of 2
    • Lift the keypad off of the keyboard as it is not attached to the phone anymore.
    • If you want to clean your keyboard do not use chemical cleaners or too much water, instead, use a damp cloth.
    • It may be tricky to get the keypad in the right position while closing the front cover for the reassembly. Ensure they are aligned properly before closing the front cover!
3 other people completed this guide.
Tim Bergmann
35 Reputation
4 Guides authored
Cal Poly, Team 3-17, Maness Winter 2010 Member of Cal Poly, Team 3-17, Maness Winter 2010
CPSU-MANESS-W10S3G17
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 2,345
