You're viewing a previously published version of this guide.  View latest version
Older Newer
Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator
Baschtl
Baschtl and 5 other contributors
Last updated on June 2, 2023
10 minutes
Easy
Community-Contributed Guide
Introduction
Go to step 1
A loose actuator screw makes the toothbrush useless as it prevents the engine to drive the actual toothbrush that is attached to the top of the device. However, repairing this failure can be achieved in just a few steps.
iFixit earns commission when you buy through these links.
  1. Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator, Prepare your tools.: step 1, image 1 of 1
    • You will need two screwdrivers:
    • a 6.5mm flathead and
    • a small Phillips #1.
  2. Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator, Open the enclosure: step 2, image 1 of 3 Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator, Open the enclosure: step 2, image 2 of 3 Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator, Open the enclosure: step 2, image 3 of 3
    • Have a look to an alternative opening procedure.
    • Take the flathead screwdriver.
    • Insert it into the slot located at the bottom of the handle and turn counterclockwise to release the bottom cap.
    • The second image shows the amount of turning needed to loosen the bottom cap.
    • Be careful with this as the plastic is not very solid. Deforming the material could result in issues when placing the device onto the charging station.
    • Hold the handle upside down, and push down on the shaft to release the internal components of the handle.
  3. Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator: step 3, image 1 of 3 Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator: step 3, image 2 of 3 Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator: step 3, image 3 of 3
    • Carefully pull the internals out of the casing.
  4. Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator: step 4, image 1 of 1
    • Take the small Phillips screwdriver.
    • Tighten the small screw that can be found near the top of the device internals
    • Pro tip: I experienced that the screw comes loose after just a few days if you do not take further actions.
    • Hence, unscrew the screw completely and put some superglue at the end of it. Then tighten it again. This prevents the screw to get loose due to the vibrations.
Baschtl
1,608 Reputation
5 Guides authored
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 160
All Time: 44,133
