Repairing Polaroid One-Step 600 Shutter
  1. Repairing Polaroid One-Step 600 Shutter, Repairing Polaroid One-Step 600 Shutter: step 1, image 1 of 3 Repairing Polaroid One-Step 600 Shutter, Repairing Polaroid One-Step 600 Shutter: step 1, image 2 of 3 Repairing Polaroid One-Step 600 Shutter, Repairing Polaroid One-Step 600 Shutter: step 1, image 3 of 3
    • THIS REPAIR GUIDE IS VERY DIFFICULT AND SHOULD ONLY BE FOLLOWED IF YOU HAVE EXPERT MECHANICAL EXPERIENCE.
    • Open the flash/ lens compartment of the Polaroid camera to a 30 degree angle with the horizontal.
  2. Repairing Polaroid One-Step 600 Shutter: step 2, image 1 of 3 Repairing Polaroid One-Step 600 Shutter: step 2, image 2 of 3 Repairing Polaroid One-Step 600 Shutter: step 2, image 3 of 3
    • Separate the flash section of the camera from the main body by unhooking the sides.
    • BE CAREFUL NOT TO YANK THE TWO SECTIONS APART BECAUSE THE BAND WIRE STILL ATTACHES THEM!
  3. Repairing Polaroid One-Step 600 Shutter: step 3, image 1 of 1
    • Open the battery/ cartridge compartment fully.
  4. Repairing Polaroid One-Step 600 Shutter: step 4, image 1 of 3 Repairing Polaroid One-Step 600 Shutter: step 4, image 2 of 3 Repairing Polaroid One-Step 600 Shutter: step 4, image 3 of 3
    • Insert spudger in between face of camera and sides where the four tabs are located.
  5. Repairing Polaroid One-Step 600 Shutter: step 5, image 1 of 2 Repairing Polaroid One-Step 600 Shutter: step 5, image 2 of 2
    • Once tabs are released, pull face of camera straight out.
  6. Repairing Polaroid One-Step 600 Shutter: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Carefully use tweezers to remove the spring from the hooks.
    • CAUTION: You may lose the spring if it pops off the hooks.
  7. Repairing Polaroid One-Step 600 Shutter: step 7, image 1 of 2 Repairing Polaroid One-Step 600 Shutter: step 7, image 2 of 2
    • Use the spudger to release the latch for the shutter mechanism.
    • Rotate the shutter mechanism clockwise until it stops.
    • If latch was successfully released, shutter mechanism should touch top plastic brace.
  8. Repairing Polaroid One-Step 600 Shutter: step 8, image 1 of 3 Repairing Polaroid One-Step 600 Shutter: step 8, image 2 of 3 Repairing Polaroid One-Step 600 Shutter: step 8, image 3 of 3
    • Release the two tabs that hold lens plate in position.
  9. Repairing Polaroid One-Step 600 Shutter: step 9, image 1 of 1
    • Remove the lens plate by pulling down, then away from the camera.
  10. Repairing Polaroid One-Step 600 Shutter: step 10, image 1 of 3 Repairing Polaroid One-Step 600 Shutter: step 10, image 2 of 3 Repairing Polaroid One-Step 600 Shutter: step 10, image 3 of 3
    • Remove the shutter mechanism from the camera.
    • Remove black latch piece from the camera.
    • Remove shutter plates from the camera.
  11. Repairing Polaroid One-Step 600 Shutter: step 11, image 1 of 3 Repairing Polaroid One-Step 600 Shutter: step 11, image 2 of 3 Repairing Polaroid One-Step 600 Shutter: step 11, image 3 of 3
    • To replace the shutter pieces in the camera, first make sure they are in the proper order.
    • The shutter piece at the bottom of the first picture belongs on the bottom.
    • The shutter piece in the middle of the first picture goes in the middle (second picture).
    • The shutter piece at the top of the first picture goes on top (third picture).
  12. Repairing Polaroid One-Step 600 Shutter: step 12, image 1 of 3 Repairing Polaroid One-Step 600 Shutter: step 12, image 2 of 3 Repairing Polaroid One-Step 600 Shutter: step 12, image 3 of 3
    • By looking at the first picture, line up the long, skinny slots on the three shutter pieces.
    • In the second picture, notice the pin inside the circle.
    • Line up the slots in the shutters with the pin inside the camera as shown in the third picture.
  13. Repairing Polaroid One-Step 600 Shutter: step 13, image 1 of 3 Repairing Polaroid One-Step 600 Shutter: step 13, image 2 of 3 Repairing Polaroid One-Step 600 Shutter: step 13, image 3 of 3
    • NOTE: The shutter pieces are not included in the first two pictures of this step because they slide around too easily for us to take pictures with them in the camera.
    • Put black plastic piece back into camera, making sure to slide tab into slot (rectangle) and onto the pin (circle).
    • Final assembly for this step should look like the third picture.
  14. Repairing Polaroid One-Step 600 Shutter: step 14, image 1 of 2 Repairing Polaroid One-Step 600 Shutter: step 14, image 2 of 2
    • CAUTION: The next two steps are incredibly difficult!
    • First, you must align the tab (circled) with the slot (rectangle).
    • Do not put pieces together until after reading the next step!!!
  15. Repairing Polaroid One-Step 600 Shutter: step 15, image 1 of 3 Repairing Polaroid One-Step 600 Shutter: step 15, image 2 of 3 Repairing Polaroid One-Step 600 Shutter: step 15, image 3 of 3
    • REMINDER: This step is very difficult and may require multiple attempts.
    • Align teal and orange circled tabs from the first picture with the respective teal and orange holes in the shutter pieces.
    • After the shutter mechanism is placed into the camera, make sure all three shutter pieces are attached correctly.
    • NOTE: When correctly attached, the shutter pieces will slide in opposite directions when the shutter mechanism is rotated.
    • To finish putting the Polaroid back together, follow steps 9 through 1 in reverse.
Finish Line
7 other people completed this guide.
Kimberly
185 Reputation
1 Guide authored
Cal Poly, Team 16-31, Maness Winter 2010 Member of Cal Poly, Team 16-31, Maness Winter 2010
CPSU-MANESS-W10S16G31
4 Members
9 Guides authored
1 Guide Comment
I'm pretty sure every type 600 polaroid camera is built the same so this should work with other 600 cameras. I followed this guide for my polaroid 640 land camera and it was exactly the same.
Camdyn - Reply
Past 24 Hours: 5
Past 7 Days: 40
Past 30 Days: 135
All Time: 35,864
