Before you begin, be sure to remove the battery.
Slide both battery locking mechanisms in the direction of the arrows.
Gently pull the battery out of the laptop.
The LCD connector is taped into its socket.
Use tweezers to carefully lift the clear tape holding the connector down.
Once you peel the tape past the gold portion of the connector, the connector should pull out easily.
If you purchased a replacement LCD with the metal brackets pre-attached, then you are finished. If not, continue reading!
15 other people completed this guide.
6 Comments
My Samsung laptop fell down so when I checked for damages everything was ok except my LCD back light is not working I hardly see what's on the screen. Please help how can I fix this problem
If your backlight is not working then the issue may probably lie in the inverter, which steps up battery voltage to power the backlight, rather than the screen itself. I am not familiar with this model, but the inverter is probably attached to the wire that goes into the LCD cable, perhaps below the hinge or just below the speaker assembly.
To pop the speaker assembly out you may have to undo some screws that are covered by components such as the hard drive or battery.
Hello, thanks for this write up, my Samsung NP300E5A fell and the display change colors & had white Lines that changes position anytime, I hardly see original color and can't design graphics as a result of this. Please what's likely to be the problem??
It's likely the LCD that needs to be replaced. If you purchase a screen on ebay or one of the laptop screen sales websites and follow this guide it should work again. Would you be able to send me a picture of what the screen is doing so I can better advise?
Brad -
