Repairing Sony Cyber-shot DSC-W290 Motherboard
  1. Repairing Sony Cyber-shot DSC-W290 Motherboard, Battery: step 1, image 1 of 1
    • Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
  2. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 2, image 1 of 1
    • Slide the blue locking tab to release the battery.
    • Slide the battery out of the camera.
  3. Repairing Sony Cyber-shot DSC-W290 Motherboard, Outer Casing: step 3, image 1 of 2 Repairing Sony Cyber-shot DSC-W290 Motherboard, Outer Casing: step 3, image 2 of 2
    • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
    • Remove the four 2.5mm Phillips #0 screws.
  4. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 4, image 1 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 4, image 2 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
    • Remove the two 2.5mm Phillips #0 screws.
    • You may have to remove the screws with a pair of tweezers when the screws are almost out.
  5. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 5, image 1 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 5, image 2 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 5, image 3 of 3
    • Turn the camera so the right side faces you.
  6. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 6, image 1 of 1
    • Rotate camera so that the back is facing you.
    • Pull the back casing directly away from the LCD screen.
  7. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 7, image 1 of 2 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 7, image 2 of 2
    • Turn the camera so that the left side is facing you.
    • Pull the left side-panel off of the camera.
  8. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 8, image 1 of 2 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 8, image 2 of 2
    • Turn camera so that the front of the camera is facing you.
    • Pull the front casing directly away from the camera.
    • The right side panel may fall off when you take the front panel off.
  9. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 9, image 1 of 2 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 9, image 2 of 2
    • Turn the camera so that the right side is facing you.
    • Pull the right side-panel away from the rest of the camera.
  10. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 10, image 1 of 2 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 10, image 2 of 2
    • This is what your camera should look like now that you have removed the casing from all sides.
  11. Repairing Sony Cyber-shot DSC-W290 Motherboard, LCD Assembly: step 11, image 1 of 1
    • Gently pull the LCD and its casing away from the motherboard as shown.
    • Be careful not to rip out any ribbon cables.
  12. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 12, image 1 of 2 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 12, image 2 of 2
    • Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard.
    • Do not use excessive force to remove the wire because this may cause it to tear.
  13. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 13, image 1 of 2 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 13, image 2 of 2
    • Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard.
  14. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 14, image 1 of 1
    • Pull the LCD and its casing away from the rest of the camera.
  15. Repairing Sony Cyber-shot DSC-W290 Motherboard, Flash Bulb Assembly: step 15, image 1 of 2 Repairing Sony Cyber-shot DSC-W290 Motherboard, Flash Bulb Assembly: step 15, image 2 of 2
    • Turn the camera so the back is facing you.
    • Remove the 2.5mm Philips #0 screw at the top of the camera.
  16. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 16, image 1 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 16, image 2 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 16, image 3 of 3
    • Tilt top casing up and towards you.
    • Carefully remove the right ribbon-wire from the top camera panel by pulling where the wire connects to the top.
    • Make sure to hold the camera with your thumb on the white square to ensure the ribbon-wire is not disconnected from the motherboard.
    • Carefully remove the left ribbon-wire from the top camera panel by pulling where the wire connects to the top.
  17. Repairing Sony Cyber-shot DSC-W290 Motherboard, Lens Assembly: step 17, image 1 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard, Lens Assembly: step 17, image 2 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard, Lens Assembly: step 17, image 3 of 3
    • Flash capacitors are dangerous! Be extremely careful when removing the capacitor from the camera. You can get shocked BADLY!
    • Remove the flash capacitor from the lens assembly.
    • Carefully place the flash capacitor away from where you are working.
  18. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 18, image 1 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 18, image 2 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 18, image 3 of 3
    • Carefully disconnect the top ribbon-wire from the motherboard by pulling where the wire connects to the motherboard.
  19. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 19, image 1 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 19, image 2 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 19, image 3 of 3
    • Disconnect the top remaining ribbon-wire by carefully pulling at the base of where the wire connects to the motherboard.
  20. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 20, image 1 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 20, image 2 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 20, image 3 of 3
    • Pull the Lens Assembly away from the motherboard.
    • You have now removed the Lens Assembly from the camera.
  21. Repairing Sony Cyber-shot DSC-W290 Motherboard, Motherboard: step 21, image 1 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard, Motherboard: step 21, image 2 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard, Motherboard: step 21, image 3 of 3
    • Remove the red clip that holds the motherboard to its casing.
  22. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 22, image 1 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 22, image 2 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 22, image 3 of 3
    • Pull back the small gray clip located on the right side of the camera to release the motherboard from its casing.
  23. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 23, image 1 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 23, image 2 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 23, image 3 of 3
    • Lift the motherboard from the casing.
    • Carefully remove the large ribbon-wire by pulling the wire where it connects with the motherboard.
    • In order to completely remove the motherboard, you must desolder the small ribbon wire from the casing.
  24. Repairing Sony Cyber-shot DSC-W290 Motherboard: step 24, image 1 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 24, image 2 of 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: step 24, image 3 of 3
    • Flip the motherboard up to turn it over.
    • When de-soldering, be careful not to burn yourself or the motherboard. You can damage or destroy the motherboard or the ribbon wire by applying too much heat.
    • Carefully de-solder the three connectors from the ribbon wire to the motherboard.
    • You have now removed the motherboard.
2 other people completed this guide.
Evan Mayer
336 Reputation
5 Guides authored
Cal Poly, Team 7-54, Amido Fall 2010 Member of Cal Poly, Team 7-54, Amido Fall 2010
CPSU-AMIDO-F10S7G54
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 18
All Time: 3,970
