Repairing Tent Buckle
  1. Repairing Tent Buckle, Sew a Straight Stitch: step 1, image 1 of 2 Repairing Tent Buckle, Sew a Straight Stitch: step 1, image 2 of 2
    • Thread your needle and tie a knot in the end of the thread.
    • We're using contrasting thread for visibility, but when you do your repair you will want to use matching thread.
    • Drive the needle through the back of the bottom material.
    • Pull the thread taut.
  2. Repairing Tent Buckle: step 2, image 1 of 2 Repairing Tent Buckle: step 2, image 2 of 2
    • Drive the needle through the back side of the top material.
    • In this case we're sewing a buckle, but you can use this stitch to sew just about anything together.
    • Align the two materials in their final position.
  3. Repairing Tent Buckle: step 3, image 1 of 2 Repairing Tent Buckle: step 3, image 2 of 2
    • Drive the needle down through both layers of material, coming out on the back side of the bottom material. Push the needle out of the material.
    • The closer you drive the needle in to where the thread came up, the smaller the stitch length. Having a smaller stitch length requires more stitches, but creates a stronger seam.
  4. Repairing Tent Buckle: step 4, image 1 of 2 Repairing Tent Buckle: step 4, image 2 of 2
    • Ensure the two layers are correctly aligned.
    • Drive the needle through both layers of fabric from the back side of the bottom material, coming up on the top side of the top material.
  5. Repairing Tent Buckle: step 5, image 1 of 3 Repairing Tent Buckle: step 5, image 2 of 3 Repairing Tent Buckle: step 5, image 3 of 3
    • Continue sewing through both layers, going down from the top and up from the bottom, as described in steps 3 and 4 of this guide.
    • When you come to the end of your material, draw the needle in between the two layers of material, under the thread of the closest stitch.
    • Slowly start to pull the thread taut. As you pull a loop will form.
    • Draw the needle through the loop and pull the thread taut.
    • Repeat the process of drawing the needle between the layers, creating a loop, and drawing the needle through the loop as described in this step.
  6. Repairing Tent Buckle: step 6, image 1 of 1
    • Cut any remaining thread and admire your work.
Finish Line
Brittany McCrigler
90,490 Reputation
142 Guides authored
1 Guide Comment
I've found that small bungee cords (or the poor-boy version, an old bicycle inner tube cut with a scissors into very many tough rubber bands just as thick or thin as you wish) is a great add-on to tent and tarp guy lines. When those big gusts of wind arrive, the elasticity of the added-on stretchy thing allows the wind to buffet the tent or tarp about, but prevents tent stakes from being dislodged, or tarps from becoming shredded. No stitches are needed when the elastic, instead of the fabric, takes the strain.
Brendan - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 5,448
