Repairing Vizio Television Cable Connection
  1. Repairing Vizio Television  Cable Connection, Repairing Vizio Television  Cable Connection: step 1, image 1 of 1
    • First, remove the (20) Phillips screws from the back plate. If your television is mounted against a wall, you'll have to remove it from your wall mounting bracket as well.
    • Don't forget the 2 Phillips screws in the motherboard area (circled in red).
  2. Repairing Vizio Television  Cable Connection: step 2, image 1 of 3 Repairing Vizio Television  Cable Connection: step 2, image 2 of 3 Repairing Vizio Television  Cable Connection: step 2, image 3 of 3
    • After removing the back plate, you'll see some circuit boards. We'll be focusing on the motherboard to the right.
    • (2) Phillips screws hold down covers over your inputs.
    • Note this screw holds down both covers where they overlap.
    • The bottom cover will not move until the 2 small Phillips screws are removed.
  3. Repairing Vizio Television  Cable Connection: step 3, image 1 of 2 Repairing Vizio Television  Cable Connection: step 3, image 2 of 2
    • Once the covers are all removed, you'll see a big hole where the cable connection is supposed to be.
    • Proceed to solder your new connection in like I did here. If you decide to replace the entire part you'll need to remove the motherboard... We'll save that for a different thread.
  4. Repairing Vizio Television  Cable Connection: step 4, image 1 of 1
    • You can then put it all back together once again in reverse order and enjoy some cable TV!
14 other people completed this guide.
Ricky
867 Reputation
3 Guides authored
TechTucson WeFixThat Member of TechTucson WeFixThat
Community
2 Members
4 Guides authored
7 Guide Comments
Are there pics of what needs to be done in order to solder the cable connector correctly?
MistaRite145 - Reply
how can I order the part to repair the coax connector for the Vizio 32 inch tv
Steven William Schwenn - Reply
how can I order the coax connector part to repair my 32 inch. Vizio TV.
WHAT part is the actual connector? Ive searched for days with NO LUCK! Its a rear mount cam twist thing;I can NOT find this part!!!!
john kowalski - Reply
My vizio tv is not functioning properly. When i switch it on. The dispaly say. The tuner is not set up. Click Menu so set it up. Then, when i click the “Menu” may lumalabas na “HDTV setting”. When i click it. It will just go back to its normal form.
jpfernandez211 - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 56
All Time: 18,255
