Repairing a Clogged MakerBot Smart Extruder+
  1. Repairing a Clogged MakerBot Smart Extruder+, Repairing a Clogged MakerBot Smart Extruder+: step 1, image 1 of 1
    • Place the extruder on a flat surface with the connection pins facing up.
  2. Repairing a Clogged MakerBot Smart Extruder+: step 2, image 1 of 1
    • Remove the 4 screws on the outer edge of the extruder using the 2 mm hex wrench.
  3. Repairing a Clogged MakerBot Smart Extruder+: step 3, image 1 of 2 Repairing a Clogged MakerBot Smart Extruder+: step 3, image 2 of 2
    • Remove the fan shroud from the extruder.
  4. Repairing a Clogged MakerBot Smart Extruder+: step 4, image 1 of 2 Repairing a Clogged MakerBot Smart Extruder+: step 4, image 2 of 2
    • Turn the extruder on its side and cut through the black seal using the X-ACTO Knife.
  5. Repairing a Clogged MakerBot Smart Extruder+: step 5, image 1 of 2 Repairing a Clogged MakerBot Smart Extruder+: step 5, image 2 of 2
    • Gently pull the two halves of the extruder apart.
  6. Repairing a Clogged MakerBot Smart Extruder+: step 6, image 1 of 3 Repairing a Clogged MakerBot Smart Extruder+: step 6, image 2 of 3 Repairing a Clogged MakerBot Smart Extruder+: step 6, image 3 of 3
    • Remove the bearing and the hobbed bolt.
  7. Repairing a Clogged MakerBot Smart Extruder+: step 7, image 1 of 3 Repairing a Clogged MakerBot Smart Extruder+: step 7, image 2 of 3 Repairing a Clogged MakerBot Smart Extruder+: step 7, image 3 of 3
    • Remove the freed nozzle and use needle nose pliers to pull out the filament that is clogging the extruder.
Aidan Tadeo
145 Reputation
1 Guide authored
UC Davis, Team 1-6, Morris Winter 2023 Member of UC Davis, Team 1-6, Morris Winter 2023
UCD-MORRIS-W23S1G6
2 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 532
