Seville Classics MSC10166 Buttons Replacement
  1. Seville Classics MSC10166 Buttons Replacement, PCB (Printed Circuit Board): step 1, image 1 of 1
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. Seville Classics MSC10166 Buttons Replacement: step 2, image 1 of 1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Seville Classics MSC10166 Buttons Replacement: step 3, image 1 of 1
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Seville Classics MSC10166 Buttons Replacement: step 4, image 1 of 1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Seville Classics MSC10166 Buttons Replacement: step 5, image 1 of 2 Seville Classics MSC10166 Buttons Replacement: step 5, image 2 of 2
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. Seville Classics MSC10166 Buttons Replacement, Buttons: step 6, image 1 of 1
    • Remove the two 8 mm screws that attach the buttons to the top cover of the fan.
  7. Seville Classics MSC10166 Buttons Replacement: step 7, image 1 of 1
    • Remove the buttons from the top cover.
  8. Seville Classics MSC10166 Buttons Replacement: step 8, image 1 of 1
    • Wipe down any dirt on the buttons.
  9. Seville Classics MSC10166 Buttons Replacement: step 9, image 1 of 1
    • Wipe down the frame that holds the buttons.
2 other people completed this guide.
Queena Phung
114 Reputation
3 Guides authored
Cal Poly, Team 15-46, Forte Fall 2012 Member of Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Members
6 Guides authored
2 Guide Comments
Great work but our problem is the micro switch itself, after exposing the circuit board I shorted the backside solder connections to cycle the fan on and off, everything works perfectly…..now I only need to know a part number so I can find a on/off micro switch.
any suggestions?
Thanks for any help you can provide
rickkingsbury@comcast.net
Rick - Reply
Is there a way to keep the fan in ALWAYS ON position. So I can control it’s ON/OFF using a smart plug?
Vish Talreja - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 4,408
