How to remove scratches from an Airpods Case
  1. How to remove scratches from an Airpods Case, How to remove scratches from an Airpods Case: step 1, image 1 of 2 How to remove scratches from an Airpods Case, How to remove scratches from an Airpods Case: step 1, image 2 of 2
    • The front and back are already scarred.
  2. How to remove scratches from an Airpods Case: step 2, image 1 of 1
    • Use 2000 grit and above fine-grained sandpaper.
    • For this tutorial, I used 2500 grit directly and then 3000 grit for a finer finish.
    • Careful when choosing a grit, a too coarse sandpaper grit will damage the airpods case
  3. How to remove scratches from an Airpods Case: step 3, image 1 of 1
    • Cotton wool and medical alcohol are used to clean the surface of the charging case.
  4. How to remove scratches from an Airpods Case: step 4, image 1 of 2 How to remove scratches from an Airpods Case: step 4, image 2 of 2
    • Clean the surface of the charging case with absorbent cotton dipped in alcohol.
    • Clean up the inside too!
  5. How to remove scratches from an Airpods Case: step 5, image 1 of 1
    • Wet the surface with absorbent cotton or a little water, and then lightly sand it with 2500-grit fine sandpaper.
    • It can be seen that the more serious scratches have been smoothed out, the polished areas have turned white, and the smooth surface has become matte.
    • This step can be performed as many times as necessary.
  6. How to remove scratches from an Airpods Case: step 6, image 1 of 1
    • It has now returned to white, but the surface is still matte.
    • If you like this matte style, you can stop
    • To restore a smooth surface, continue sanding with 3000 grit sandpaper in the same way as in the previous step.
    • The finer the sandpaper, the smoother it will be.
  7. How to remove scratches from an Airpods Case: step 7, image 1 of 1
    • Refreshed now!
This will give the charging case a refreshed look instead of a dirty, scratched surface.
28 other people completed this guide.
Special thanks to these translators:
zh en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Z.Heng
3,640 Reputation
3 Guides authored
8 Comments
Extremely convincing, especially the last picture.
Ludger - Reply
感谢作者!我的AirPods也布满了划痕!
Zhang Boyang - Reply
Kann man auch Polierpaste nutzen wie sie für Kunststoffdisplays benutzt wird?
neo1983-jahn - Reply
How big can the scratches be ?
Albert zweisteim - Reply
How do you get it shiny again?
lucas cheraki - Reply
Past 24 Hours: 17
Past 7 Days: 173
Past 30 Days: 861
All Time: 77,757
